Flipped D300 behind AW-4.. Any unusual install issues?
Hey guys, (I was referred over to you unibody fella's from POR regarding my question)
My buddy has sold me a DEO Flipped & Twin Sticked Dana 300 with a 5/16" Clocking Ring that he had behind a NV3550 in a 2000 TJ.
I'm putting it into my 1997 TJ behind a 23 Spline 1999 XJ AW-4 that I swapped in last summer.
I'm just wondering if there are any unusual issues I might encounter with the install. Neither of us are positive if the AW-4 Output Shaft will be too long for the D300 with the 5/16 Clocking Ring. Anyone encounter this?
Its not a big deal to cut the shaft, but we only have 3 days to do this and return his very built TJ to stock, so any prior fault finding will help speed up the process.
Thanks in advance
Scotty
I got some info from a fella on JU basically stating that if the D300 has the Sealed Imput Bearing that comes with the DEO Kit and a 5/16" Clocking Ring, then I can just Trim the AW-4 Output Shaft 1/16th and grind down the D300 Imput a tad as well.
Makes sense I guess...
