Old January 9th, 2005, 14:57
Harvo's Avatar
Harvo Harvo is offline
TC Drop Question
I'm about to do an RE 5 inch lift on my 93. I was going to wait to see if I needed the SYE or If I could do without but...
I have drop brackets and braces to put on. I hear they are a pain to line up. If I put the TCase spacers in for now, then need the SYE after all...
1. Will I have to remove the TCase spacers?
2. If I do, will the hole alignment for the DB braces get all whack again when I pull out the bolts?
3. When you order an SYE from DPG, do they know how long the drive shaft should be for each application of lift? (IE. can I order one up ahead of time and get one that works?)
Thanks
HarveOut-
Old January 9th, 2005, 15:15
MontanaXJ's Avatar
MontanaXJ MontanaXJ is offline
Re: TC Drop Question
You can get a drive shaft made from your factory specs. Call Dirk and he should be able to get you on the right track on how/what to measure.
Old January 9th, 2005, 15:33
Harvo's Avatar
What are you doing on here? You are supposed to be out testing that new suspension.
Thanks for the info. I regret not ordering that stuff when I ordered the lift. I want to do it all together, so now I have to try and get the SYE and DS here before my garagetime runs out on Wed.
Can you do the AA SYE without removing the TCase?
Old January 9th, 2005, 17:03
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: TC Drop Question
its much easier to remove the case - too many small parts to deal with otherwise...
stupid springs...
you have to take the case apart which means supporting the trans and removing the x-member anyway - might as well pull the case and work in the light and right side up....
HTH
-Ranger
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old January 9th, 2005, 18:52
RCP Phx RCP Phx is offline
you have to take the case apart which means supporting the trans and removing the x-member anyway - might as well pull the case and work in the light and right side up.... -Ranger
It does not require the crossmember to be removed,Ive done several in the vehicle with ease!
Old January 9th, 2005, 20:08
bj-666's Avatar
bj-666 bj-666 is offline
-Ranger
WHAT u don't have to remove the case and i don't know what springs u are talking about doing a sye all there are are snap rings that can be a pain without the proper tools.
4 wheel drive release question?? Lewis OEM Tech Discussion 12 May 14th, 2006 08:27
Transfer case drop question Urban Redneck Modified Tech Discussion 3 March 25th, 2004 17:31
transfer case drop question... rngrfrd2000 Modified Tech Discussion 3 March 17th, 2004 22:07
Headers Question Garthbmn7 Modified Tech Discussion 1 December 6th, 2003 05:40
7.5" lift, Drop pitman arm question... LAWNMAN323 Modified Tech Discussion 13 April 2nd, 2003 08:27
