Old January 6th, 2005, 16:03
isaacson isaacson is offline
Can I use Comanche or Dodge leafs to lift my xj?
Can I use Comanche or Dodge leafs to lift my xj? if so what kind of ride am I going to get and what kind of lift?
thanks
Old January 6th, 2005, 18:09
baseballneal86's Avatar
baseballneal86 baseballneal86 is offline
Re: Can I use Comanche or Dodge leafs to lift my xj?
Short answer....Yes
Do a search and you will find more than enough information on it.
Old January 6th, 2005, 18:28
MJ1990buildup's Avatar
MJ1990buildup MJ1990buildup is offline
any 2.5inch wide leaf will work
just place them in the right spot, comanche leaf's flex niiice
Old January 6th, 2005, 18:35
mn_xj mn_xj is offline
the main leaf in an mj is longer eye to eye than a xj
Old January 6th, 2005, 18:40
i've made packs using stock xj main leaf's cut to lenght and slipped them in the pack
2 main leaf's for each pack, add a shackle and you've got 5inches of lift
bigger lift, now what??? tommy1102 Modified Tech Discussion 9 March 9th, 2005 08:15
XJ Lift Question Blackash132 Modified Tech Discussion 14 February 22nd, 2004 14:13
Max lift before I have to change contol arms? simonsxj Modified Tech Discussion 15 February 1st, 2004 08:09
XJ lift Wesley Modified Tech Discussion 2 January 12th, 2004 22:18
YJ leafs on XJ? KJR93XJ Modified Tech Discussion 7 January 2nd, 2004 07:45
