Old January 4th, 2005, 14:25
98XJ's Avatar
98XJ 98XJ is offline
Question Bronco II lockout hubs VS. WARN 5X4.5 lock out hubs.
Does anyone know what is the real difference between Ford Brnco II (27 spline) lock hubs and Warn 5X4.5 conversion lock hubs?
Warn rep told me that Conversion hubs are a bit stouter.
What is the deal ?
TIA
Old January 4th, 2005, 14:32
Jeepin Jason's Avatar
Jeepin Jason Jeepin Jason is offline
NAXJA Member #1100
Re: Bronco II lockout hubs VS. WARN 5X4.5 lock out hubs.
AFAIK the hubs themselves interchangeable. A friend of ours has replacement Warn hubs on his B2 and they're identical to my Warn 5x4.5's.
Old January 4th, 2005, 17:19
BillR's Avatar
BillR BillR is offline
Toy Jeep driver!
I've also used Bronco II Warn hubs on a Milemarker conversion kit. It works too!
Old January 4th, 2005, 21:47
EricsXJ's Avatar
EricsXJ EricsXJ is offline
NAXJA Member #616
Aren't the splines inside the Warn hubs heat treated?
www.ericsxj.com
Old January 5th, 2005, 20:32
blackdogxj's Avatar
blackdogxj blackdogxj is offline
they are really the same, for the front and also for the full float kit. i had a set of warn front hubs on my bronco 2 and i put them threw hell and they never gave up...u just have to make sure that u get them off a bronco 2/ranger/explorer with a dana 35 front axle
Old January 6th, 2005, 05:41
fordtech's Avatar
fordtech fordtech is offline
Talking Re: Bronco II lockout hubs VS. WARN 5X4.5 lock out hubs.
yep interchangeable. The xj kits were designed using ranger/bII/explorer hubs. I had factory locking manual hubs on my 89 ranger, couldnt break em. I broke the inner stub shaft before I broke the hub.
I guess you could even use auto locking hubs.........and really have a turd axle!!!
Old January 6th, 2005, 08:39
lankchevy lankchevy is offline
soo, could u pull the hubs, rotors, outers, discs, and what else from a bronco 2. then use those to build your own lock out hub kit? sounds interesting. has anyone accualy done this? does it all just bolt up? and it would be awesome if some broncos came with 297 joints. i would guess they used 260 tho.
kolby
Old January 6th, 2005, 10:10
NAXJA Member #1100
I think you still gotta have the custom spindles that let all the pieces fit on the Jeep D30 knuckles, and possibly a spacer or two. No need to get the B2 brakes though I don't think.
Old January 6th, 2005, 12:57
fordtech's Avatar
kolby
The Ranger/BII/ Explorer front ends are just like the full size fords. They have races in the rotor and run regular tapered roller bearings that run on the spindle. The conversion basically does this. You would need a spindle made, I dont think the ford one would work for this. Same with the stub shaft. The rotor is another consideration. Otherwise its the same hardware. Im curious, i havent had a ranger/bII/Explorer apart in a few years. You maybe able to make alot of the parts work.
Old December 7th, 2005, 12:13
davedanger davedanger is offline
Ford only used the 297/760 u-jont on Ranger/BII/Explorer, axles were D28 or D35 independent (twin I-Beam). Later (95+ ?) used a-arms with a unit bearing.
Some CJ's with D30 have the the same spindle diameter as ford (were the bearing rides).
May be using CJ spindles with ford hubs could work?
Old February 28th, 2006, 18:08
JCByrd24 JCByrd24 is offline
On a Time Out
There is a difference between the two hubs. I was just reading an artical now can't find it. The pn 37780(1) are an upgraded hub based on the Explorer hub but design for the full float kit. It is a little more robust but they are interchangeable. Warn needs to discontinue the original Explorer/Ranger PN and just sell the new one...
P.S. Also posting because I have an Explorer and want to swap in a D30 from an XJ but keep my hubs(+ spindles, rotors, outshaft, etc)...basically alleviating the $1000 for a hub conversion.
found the link: http://www.therangerstation.com/Maga...04/offroad.htm
Old December 9th, 2008, 00:20
Headshot's Avatar
Headshot Headshot is offline
I had the warn hubs on my 85 B2 and i put it through hell all the time lol...the only time i thought it was broken was when a buddy of mine hit the passanger side front end and i couldnt get the switch to move...but i just kept workin it and eventually it started working just fine...i drove that thing into the ground lol
BEARING HUBS!!!! What's the deal?!? CheapXJ Modified Tech Discussion 32 March 18th, 2005 17:25
Milemarker lockout hub VS. Warn lockout hub (standard hub) 98XJ Modified Tech Discussion 1 January 2nd, 2005 16:30
lockout hubs jcamp1221 Modified Tech Discussion 3 April 13th, 2004 21:35
Warn HS9500i flexj For Sale: Private Party Only. XJ ITEMS ONLY 0 December 8th, 2003 18:43
Warn D44 Lockout hub bolt O-rings? Jeff 98XJ WI Modified Tech Discussion 2 September 4th, 2003 14:29
