Old December 23rd, 2004, 03:16
Chancer's Avatar
Chancer Chancer is offline
Removing metal windshield trim
I've done the search, but I can't seem to find how to carefully remove the metal trim from the windshield: I see it's held in by clips, so do you just push the stops back from the clips, or does it prise out some other way? I'd like to do it as carefully as possible, as I want to see if the leak causing the footwell puddle is due to rust up against the windshield, fix the problem and put it all back together without parting with more cash. Also, any tips for stopping small rust spots from increasing would be greatly appreciated. Thanks.
Old December 23rd, 2004, 21:27
Lou's Avatar
Lou Lou is offline
I have not Confirmed, or I used a BAD email Addy
Re: Removing metal windshield trim
The clips are stronger than they look.
There is a tool for this, but you can use/make an 'L' shaped tool.
Old December 24th, 2004, 01:12
Chancer's Avatar
Thanks for that Lou - another thing to keep me occupied over the Christmas break!
Metal windshield trim bzdel2441 OEM Tech Discussion 10 November 8th, 2004 04:16
Windshield Trim REDDOGG.XJ OEM Tech Discussion 4 January 1st, 2004 14:09
Thanks, new windshield with gasket not trim 8991XJ OEM Tech Discussion 4 October 12th, 2003 18:39
Metal to metal noise offroadman83 OEM Tech Discussion 4 April 30th, 2003 22:53
Replacing metal 5 piece windshield molding with new Rubber molding Frank G OEM Tech Discussion 6 April 30th, 2003 22:14
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
