Old November 24th, 2004, 11:57
BobCSmith's Avatar
BobCSmith BobCSmith is offline
Stereo Wires
We have a 91 XJ, orginal wire harness to the stereo was cut, and we are re-wiring to install a new head unit. One wire we can't seem to figure out is, what color is the Illumination wire, were thinking it maybe the purple white?
Old November 24th, 2004, 12:16
red91's Avatar
red91 red91 is offline
Re: Stereo Wires
Here you go. This should answer your ????'s...
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Mopar Plug Wires Black & Tan OEM Tech Discussion 23 June 18th, 2013 17:09
Too many wires! HossHoffer OEM Tech Discussion 7 June 10th, 2006 13:37
Goofy stereo problem Phil Modified Tech Discussion 5 October 25th, 2004 00:13
Rock-Trac Speedo wires help? Thor Modified Tech Discussion 1 August 29th, 2004 10:01
How to properly check the plug wires? Bender OEM Tech Discussion 1 July 8th, 2003 12:15
