Old November 18th, 2004, 12:46
Harvo's Avatar
Harvo Harvo is offline
Crown Victoria 8.8
I can get an 8.8 rear off of a wrecked 97 police edition Crown Victoria. It has disc brakes already like the desirable Explorer rears. Does anyone know a reason why it wouldn't work just like the explorer 8.8? I know the gears will be really high and wack, but it should accept a carrier change just like anything else right? Does anyone know if the spline count is the same as the Explorer? Has anyone else ever used a crown vic rear?
I haven't looked at it yet but for $100 is sounds promising.
Thanks
Old November 18th, 2004, 13:03
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Crown Victoria 8.8
check the WMS to WMS measurement. The exploder rears are about 1.5" smaller than the stock cherokee axles, and the Ranger 8.8's are about 3.5" shorter (wms to wms) than the stock cherokee axles... making spacers needed to look the same...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old November 18th, 2004, 13:12
BrokenXJ BrokenXJ is offline
I think it's 28 spline.
The width of an explorer 8.8 is 59.5" wheel mounting surface to surface. If the Vic width is wider, it may be worth it in shorting some longer 31 spline shafts. The explorer rear is about 1.5" narrower than the XJ, and is off-center. Post the width if you figure it out.
I've an 8.8 and you never break it with the 4.0L motor.
Old November 18th, 2004, 13:15
goodburbon's Avatar
goodburbon goodburbon is offline
If I am not mistaken the crown vic 8.8 has less splines like the mustang. the carrier can be changed. Also does the housing have a bracket in the center of the diff like a mustang rear end. you'll have to check the tag numbers to be sure on the ratio, and spline count/axle diameter.
Old November 18th, 2004, 13:57
RKBA's Avatar
RKBA RKBA is offline
NAXJA Member #1012
that's a 28 spline c clip rear end. I think there are better and easier alternatives out there.
For a low-buck upgrade for the Dana 35, I would run the 97+ Chrysler 8.25 with junkyard ZJ discs. That would give you a reasonably strong bolt in diff as well as the discs you are looking for.
Old November 18th, 2004, 15:06
Harvo's Avatar
Didn't know that about the 8.8 offset. What do most guys do? Just run them like that? I guess with a CV driveshaft it doesn't matter much does it?
I can get one of those with 4.10 gears already in it. With the 4.0 and the auto tranny what would be the ideal gears for 33's? 4.10s or 4.88s?
If I can get away with 4.10s then all I have to do is throw a lock right in and change the front then I'm done.
Old November 18th, 2004, 16:03
Gil BullyKatz's Avatar
Gil BullyKatz Gil BullyKatz is offline
Check the bolt pattern as well...
go with an Explorer 8.8...
Old November 18th, 2004, 16:05
rust bucket xj's Avatar
rust bucket xj rust bucket xj is offline
bolt pattern would be right on, width prolly too narrow, spline count maybe 31 since its out of a cop crown vic
The big difference between car vs truck 8.8's are the process used to make the tubes, truck tubes are a good deal stronger
Old November 18th, 2004, 16:06
the offset aint bad, depending on the amount of lift i can be run with no SYE. But normally it requires an SYE.
33s and 4.10s comes out feelin like 31s on 3.55 gears so you would be fine
Old November 18th, 2004, 16:15
oh and for some readin on whats all involved or to answer some questions you may have not thought about yet or just cuz you wanna check out my site
http://xjfanatic.com/ford88.php
swapping 8.8 for D35 BLUTO Modified Tech Discussion 16 July 26th, 2004 07:30
Detroit locked 8.8 w/discs fordsux74 For Sale: Private Party Only. XJ ITEMS ONLY 8 June 3rd, 2004 05:35
Explorer 8.8 csudman For Sale: Private Party Only. XJ ITEMS ONLY 23 January 22nd, 2004 05:46
8.8 swap, what about the ABS? Adamimal Modified Tech Discussion 4 November 18th, 2003 05:54
8.8 and driveshaft questions egon Modified Tech Discussion 8 June 11th, 2003 13:08
