Old October 2nd, 2004, 15:08
SouthernXJ's Avatar
SouthernXJ SouthernXJ is offline
No start, dont think it's NSS....
91 XJ stock 4.0 auto.
For the past month or so it;s been slow to start. Kind of like it's fuel starved.
Recently it decided it just dosent want to start. If I connect the battery, it will sloooooowly try to turn over for about a second. Then nothing. Try to crank it again, nothing. Everything (radio, interior, headlights) works but the starter dosent even attempt to turn.
I've had the starter tested, it spun l like new.
Had the battery tested, holds a charge fine.
Replaced the negative battery cable.
Cleaned the positive clamp.
Cut back the positive lead and reatached to clamp.
Anyone have any ideas? I's suspect the NSS if it didnt attempt to spin the first time I turned the key. It's almost like the starter cant turn the flywheel. Open to suggestions.....
Old October 2nd, 2004, 16:22
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: No start, dont think it's NSS....
Well, you're right that it's not the NSS, because that would not allow it to start at all. How about the starter relay or solenoid? I think what you have to do next is get a voltmeter and see if you can determine what voltage is reaching the starter, and how much drop there is when it tries to crank, so you can determine whether it's in the cable, the relay or the starter. You can also get an ammeter that just hooks over the positive cable and reads the amps it draws, which might tell you something. One possibility is that the starter test was uninformative, and there is a bearing problem that causes it to bind under load, or it's burned out and spins nicely under no load but doesn't have the oomph to turn the engine. In this case the starter will pull a great deal of current (or cause a large voltage drop in the cable). I suspect the starter.
Old October 2nd, 2004, 16:43
SouthernXJ's Avatar
Iiiiiiiiiiinteresting! It sounded to me like it couldent turn the flywheel. So, I'll have to hook up the meter and check from that big drop.
please try to help me (nss) jumpman23_217 OEM Tech Discussion 15 September 11th, 2006 09:51
jump nss #30 neutral error/help dallas xjs OEM Tech Discussion 9 September 15th, 2004 19:45
No start symptoms, need advise.. June OEM Tech Discussion 8 December 11th, 2003 10:01
NSS Question? XJ311 OEM Tech Discussion 4 December 8th, 2003 12:39
'88 Chief Rough Idle or No Start or Perfect Start Hawaiian Style OEM Tech Discussion 8 June 9th, 2003 14:51
