Old May 18th, 2004, 17:29
atowley atowley is offline
4 litre H.O swap vs. v8 swap...
Well guys, it's time to swap in an engine. I have a 89 Jeep XJ with all the goodies. My old 4 litre is finally giving up the ghost. So I'm prepping for an engine swap. Would you rather go to a newer H.O motor and change harnesses and all that comes with it? Or do a v8 swap? I'd love to do the v8 swap. Any comments? For those that have done the v8 swap, what drivetrain did you use? Chevy, Mopar, Ford??? Thanks,
Adam,
Old May 18th, 2004, 18:10
REDXJ4FUN's Avatar
REDXJ4FUN REDXJ4FUN is offline
I have not Confirmed, or I used a BAD email Addy
Re: 4 litre H.O swap vs. v8 swap...
well if you want a V8 prepare for alot of work. you can use a renix block with n HO intake and head and get the best of both worlds. and you can stroke it aswell. But basicaly by staying with the 4.0 you keep it much simpler and easier since you realy don't have to change the wireing much at all.
Old May 18th, 2004, 18:42
ZmOz ZmOz is offline
With a V8 you will need many thousands of dollars in custom parts, and many many many many many hours of labor trying to make it all fit. If you manage to get it in there and make it run it's probably going to overheat. I would love a V8 in my XJ but it just isn't practical. For all the money you would spend getting a stock, ~200hp V8 in there you could build a really nice ~275hp 4.0 stroker.
Old May 18th, 2004, 19:19
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
I would keep it as a Renix and do a stroker rebuild.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old May 18th, 2004, 23:41
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Agree. A stroker rebuild will add a substantial amount of power over a stock rebuilt 4.0 and you won't need to mess about with putting together custom parts to make a V8 work.
I'm in the middle of building a 4.6L stroker myself so you could follow my guide:
http://www.angelfire.com/my/fan/stroker.html
For more stroker info. go to http://www.jeep4.0performance.4mg.com/stroker.html
Old May 19th, 2004, 09:19
MJ_Chubs's Avatar
MJ_Chubs MJ_Chubs is offline
I guess I'll play devil's advocate and say swap in the V-8. Yeah, it'll be a lot of work. The cooling and your exhaust will probably be some of the issues you'll have to deal with. Also, I'd plan on swapping a new driveline in, if you haven't already. If you're going to go with a V-8, do something unique. I'd suggest an LS1 or an LT-1. Try to maintain as many of the stock features (AC, Cruise, etc) as possible for that sleeper look. Go for it.
Old May 19th, 2004, 10:27
GAdawg GAdawg is offline
Thumbs up Re: 4 litre H.O swap vs. v8 swap...
I will also add vote for the V8. I have an 89 and did a Chevy 350 swap in. With regards to some of the comments on doing this. It is less difficult than most would think as far as custom work. Advance Adapters makes motor mounts and a bellhousing to meet up with the AX15 and headers that will route the exhaust properly. As far as cost, yeah it will be somewhat expensive but I can't imagine much more than doing a stroker on a 4.0. Don't you have to redo the fuel injection for a stroker? That was the most expensive part of my rebuild to a V8 (2K for a Holley 950 system). Anyway, if you are interested in more details on what I did feel free to PM me.
Old May 19th, 2004, 12:40
CRASH's Avatar
CRASH CRASH is offline
$150 for 24 lb/hr injectors is the extent of fuel system mods for most strokers. Maybe an AFPR ($100) if you want to tweak fuel pressure.
CRASH
Swap 4.0 for 4.0HO DADDJP Modified Tech Discussion 2 August 18th, 2005 18:46
Valve cover H.O. (H.O. swap left me uncovered!) JBrobeck Wanted: Private Party Only 2 April 3rd, 2004 14:40
Finished D60/D70 axle swap XJoachim Modified Tech Discussion 40 December 9th, 2003 20:35
2.5L to 2.8L swap? bigoltrux77 Modified Tech Discussion 11 September 8th, 2003 18:17
engine swap prep work tinyNHxj Modified Tech Discussion 17 July 12th, 2003 11:10
