themud
- Scottsdale AZ
Ok so I went and did the 99 manifold swap to my 95 it wasnt really that hard at all and cleaned my for now stock throttle body and had my injectors cleaned and flow tested and now I have this crappy long start up time???? I dont know whats causing it it seems to take like 7 or so seconds of straight cranking before it turns over then when it does its real weak running for like 2 or 3 secs then goes back to normal...Im thinking the pump is going out because if I start it then after a minute or so then turn it off and restart it it starts right up??? I just cant figure this one out :huh: am I just not getting enough fuel all around?? or is it a IAC motor finally going on vacation or maybe just the pump is finally dying on me didnt have any of these problems before hand and it usually started on the first or second rev of the motor before...lets hear them ideas!!! :yelclap:
