Old April 14th, 2004, 18:14
Atl XJ's Avatar
Atl XJ Atl XJ is offline
Talking Dynomax Ultraflow
Alright, I did a search about highflow mufflers and I havent heard anything bad about the Dynomax Ultraflow exhaust. Any reason I shouldn't run it on my 95 4.0l/aw4? Its my DD. My stock exhaust is shot from the catalytic converter back and I'm planning on buying a high flow cat (pre OBDII) with 2 1/4" pipes to go along with it. Any reason why I shouldn't?
Thanks
Old April 14th, 2004, 20:04
rngrfrd2000 rngrfrd2000 is offline
Re: Dynomax Ultraflow
a flowmaster is like having a skid plate ......trail tested
Old April 14th, 2004, 20:13
Weasel's Avatar
Weasel Weasel is offline
Dynomax's are just as good if not better then Flowmaster. Good muffler, no reason not to run one.
Old April 14th, 2004, 20:19
verrive verrive is offline
I have not Confirmed, or I used a BAD email Addy
I just got one a few weeks ago. IMO sounds good although it's dang big. It was cheaper than the Flowmaster 40 by $60 where I got mine(as I can't weld) and I have overall been happy with it.
- Kevin
Old April 14th, 2004, 20:33
green rust green rust is offline
You can get it in a welded version like the flowmaster. I put one on my 95 xj 4.0/aw4 a year ago and it is great. It doesn't have the annoying drown that the flowmaster has at cruising speeds, but it still has that performance sound. It also flows better than the flowmaster. Two thumbs up
Old April 14th, 2004, 20:45
Atl XJ's Avatar
Talking Re: Dynomax Ultraflow
I saw their Super turbo catback system on Summit for $120. Is that comparable to the ultraflow?
Thanks for the responses, the only advantage I can see for Flowmaster at this point is how tough they are built.
Old April 14th, 2004, 22:42
1986xj's Avatar
1986xj 1986xj is offline
The dynomax on my F350 is shot already.... less than 2 years. The rear outlet is just in there flopping around when you move the tailpipe. Never had a flowmaster do that. It's all good though as the warranty will cover it, but I guess I'll still be paying labor for the R&R.
Mike B.
Old April 15th, 2004, 01:18
jjvande's Avatar
jjvande jjvande is offline
anyone here use resonators to tune the sound...i dont know much about where to get em, or if they'd work on the 4.0. i like the idea of a bomproof flowmaster and a very small resonator to tone it down a bit. woud it work?
Dynomax Cat-back Townie OEM Tech Discussion 7 February 27th, 2004 09:34
Dynomax Cat-back Install xxxj-va Modified Tech Discussion 4 October 28th, 2003 06:32
Brakes and Exhaust budha808 Modified Tech Discussion 9 July 23rd, 2003 16:02
airflow performance upgrades BLUTO Modified Tech Discussion 9 April 23rd, 2003 23:15
