over the knuckle steering conversion
Big Red
Roscoe, IL 61073
I just replaced my steering on my xj when I installed a built dana 30 and I was just wondering how easy/or hard it is to install the steering above the knuckles rather than under it as it the stock set-up? Would it be possible to just mount the system above the knuckes or do extensive mods have to be done to rework the system? Just wondering. The xj steering system is pretty straight forward.
The over the knuckle tie rod flip from Goferit Off Road is easy to do and raises the tie rod about 2 to 3 inches and the price is right. I'm very happy with mine.
Shimmy wanted to see a picture, so here it is with an Alumiflex tie rod.
is.php
awesome man, how much does that little conversion cost? is it really as simple as $20 and unbolt/weld and you're done?
brandon
brandon
Almost that simple. You do have to drill the TRE hole out to 3/4" before you can insert the insert. Other than that, yup it's that simple.
Oh yeah, they say to tack it in, but I urgently recommend you lay a bead all the way around the lip. If your tack job doesn't get into the knuckle well, the insert will come off with the TRE the 1st time you try removing it, and that's a bitch to get off without damaging the rubber bootie.
tysonxj said:
** stupid question alert **
So for an XJ you only install this on the driver side?
correct
I thought that to correct the steering issues, the steering should be on top on the passenger side. Does doing just the driver side affect the steering that much? Those inserts can be used on the passenger side, right?
Thanks
The only way to make it work so that you can use the Goforit inserts on both side would be to find European/right side driver steering links and flip them. Or you can design/make new links that will work also, but since your drilling your knuckles anyway, you can go with Heims or even larger TRE's and not use the inserts at all..
If you put the drag link end ontop of the knuckle you are going to have to do the same with the Tarckbar mount on the axle end.
I will soon have some pictures of my setup when it is done, hopely the beginning of May. New links, inverted Y, with Heims over-the-knuckle and ORGS TB relocation bracket.
No, you have to do it on both sides. The steering has to be moved over the knuckle on both sides. You also have to move the track bar up to keep the steering geometry correct and not cause bumpsteer, and you have to move the sway bar links up because the raised steering links will hit them. ORGS (now JKS) makes all the parts to raise the track bar and the sway bar links.
TJ steering is not with the tie rod knuckle to knuckle, it is exactly the same as an XJ.
Both sides.... no
Track bar......no
Bumpsteer.....no
Sway bar links.......yes
TJ......I dunno, I drive an XJ.
This upgrade is for factory links, which means a factory drag link cant be flipped. The only way to do this on the passenger side is to use a right hand drive drag link and flip IT.
If you have bumpsteer,which I don't, I don't think it would be from raising one end of the tie rod with this flip.
I have NO negative effects on mine with 6.5" of lift. Matter of fact, flipping the TRE actually levelled ot my TR.
YOUR actual results may vary.
IMHO, Jeep should have done it this way in the first place. But then I guess lots of stuff woulda been hitting.
Hey Goatman, Now that I think of it, I never used a sway bay in the furst place, but I did have to cut off my SB brackets. BUt like you said, JKS makes the correcting accessories.
Remember your steering is adjustable. And if you have any kind of lift you should have an adjustable or drop bracket for your track bar. If you flip the tie rods there should be enough adjustment in the drag link to compensate. The key to avoiding bumb steer is to get you drag link and track bar parrallel, traveling the same arc.
oh Do not get the rustys over the knuckle steering. It is good beefy stuff but if you have a lifted XJ is makes your steering angles suck.
Okie Terry said:
Both sides.... no
Track bar......no
Bumpsteer.....no
You caught me not reading the whole thing. :)
I didn't see that what you were talking about only raises the drivers side. There is little advantage to doing that, although it's easily a good modification to pick up an inch or so of tie rod clearance.....I say an inch or so because you're raising one side about 2" and the other side stays the same. I'd do it if I had stock steering, although this does nothing to correct or improve steering angles.
I was referering to an OTK set up which is what the original question was. To improve steering angles both sides need to be raised, then the track bar needs to be raised, and so on. A right hand drive drag link can be ordered through the Jeep dealership, and would work with the Goforit inserts to flip the taper to the top of the knuckle. Really, this is a very simple way to gain clearance and improve angles using factory style parts, and using the ORGS stuff to raise the track bar and sway bar links would make this doable to anyone who had access to a welder, without any custom modifications. I still wouldn't recommend this with 35" or larger tires, the stock drag link just isn't up to the stress of tires over 33", and with a tall lift it's barely adequate for 33's.
Thanks, now we're on the same page.:)
