Old April 9th, 2003, 04:30
SV1CEC's Avatar
SV1CEC SV1CEC is offline
Front driveshaft compression travel available?
Folks,
For those of you with a 4 cyl. manual XJ, with the double cardan front driveshaft, could you please tell me how much compression length do you have available?
I wanted to replace my CV driveshaft with a double cardan one, and I found one locally. It is not from an XJ, and even though it fits the 231 yoke I have it has only about 1 to 1.5 cm of compression travel left, when installed.
I wouldn't like to push the driveshaft through my transfer case, so I would appreciate a measurement.
Rgds and tnx in advance
Old April 9th, 2003, 12:02
ashmanjeepxj's Avatar
ashmanjeepxj ashmanjeepxj is offline
Re: Front driveshaft compression travel available?
Originally posted by SV1CEC
Folks,
Im guessing you want to know the throw of your CV joint?
Measure the Slip spline throw, or travel 1330s are about 3 5/8" and 1310s are 3 7/32".
My junk yare drive shaft find measures to a 3 6/32in so its a 1310 slip spline.
Teh cherokees have the 1310 joints though a 1330 is idential in size they are different.
My foudn drive shaft had written in pen 84 bronco, but who knows what it really cam off..
Heres a pic, the top shaft I bought to use the double carden,
the middle shaft is the CV 1310
the bottom shaft si a 1360 1ton dive shaft for size comparison.
Old April 9th, 2003, 13:48
SV1CEC's Avatar
Re: Re: Front driveshaft compression travel available?
Thanks for taking the time to answer.
What I want to know is this:
My front driveshaft has a spline in the middle towards the axle, so that it extends and shortens as the axle moves up and down. When it is installed on the truck, mine has only about 1-1. cm of travel, until it reaches its full compression. That seems very little to me. On a small drive I took the truck for this afternoon, the driveshaft run out of compression travel when the axle' left side was in full compression or when it was almost fully dropped.
I plan to have the upper part of the driveshaft shorten, but I need to know how much to cut.
Tnx
Old April 9th, 2003, 16:44
RCP Phx RCP Phx is online now
The stock fronts have about 3" of yoke slip!
Old April 9th, 2003, 19:57
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
what you need to do is pull the shaft and measure from yoke to yoke. Take you shaft to a reputable driveshaft rebuilder/repairer. he will figure it out for you. If you are not lifted like me my measurement will not help you!
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old April 9th, 2003, 22:13
SV1CEC's Avatar
Dear Ghost,
You probably didn't notice that I am located in Athens, Greece. Reputable driveshaft stores do not exist. The only shops which do some work on driveshafts are those dealing with truckers (I mean the ones with 14 more wheels than we have, or something similar).
My XJ is currently standing at almost 6", if that helps.
Tnx and rgds
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 14:04
Front Driveshaft XJBill Modified Tech Discussion 3 November 28th, 2003 15:06
front driveshaft problems shizza-my-nizza Modified Tech Discussion 5 September 7th, 2003 23:20
Front Driveshaft Conversion 1986xj OEM Tech Discussion 22 June 30th, 2003 21:28
Front driveshaft rebuild questions woody Modified Tech Discussion 4 June 3rd, 2003 10:50
