Old February 15th, 2004, 14:40
BOB's Avatar
BOB BOB is offline
MWC geezer
Rock Rails
I have a 1995 Jeep Country. I only have a two inch lift and 30's. I am looking to put on some Rock Rails. I am a bit concerned about some trail areas that have sharp breakover hills. I have done some research. Just need other opionions. Also, any advice on how best to mount them.
95 XJ Country/ 87 MJ Pioneer
If you can read this, thank a Teacher. If it's in English, thank a VETERAN!
Old February 15th, 2004, 15:46
juicexj24 juicexj24 is offline
Kevin's Rocker Skids.
www.kevinsjeepparts.com
Can't beat the price. Super strong. Juice
Old February 15th, 2004, 15:48
Wiley Coyote's Avatar
Wiley Coyote Wiley Coyote is offline
Bob, If you are worried about the ground clearance I’d weld the rails into the lower rocker panels. There are a couple of guys that were making them out of 2” x 2” and 2” x 4” steel and cutting and welding them into the lower rocker panels. They look nice, hell for stout and no loss of ground clearance. Do a search under the modified section for “rock rails”.
Old February 15th, 2004, 20:57
bburge's Avatar
bburge bburge is offline
Lost in Translation
Your tranny/xfer case crossmember will hit before your rock rails...
bburge
Old February 16th, 2004, 07:53
kevin s kevin s is offline
ajsoffroadarmor.com
Old February 16th, 2004, 12:58
96xjeeper's Avatar
96xjeeper 96xjeeper is offline
bburge
He's right and if you don't already have them I would also look into armor all around, transfercase, fueltank, and front end steering componenets. for a start all stock skids will do, they are cheap and easy to find. but as you get HARD i would look into after market stuff. Good Luck
Old February 16th, 2004, 13:14
Jason A-33's Avatar
Jason A-33 Jason A-33 is offline
Custom 4x4 makes a good product. I have yet to bend them
Old February 16th, 2004, 16:52
96xjeeper's Avatar
Originally Posted by kevin s
ajsoffroadarmor.com
I have AJ's 2x4 rails they are SUPER. I hit them pretty hard more than once and they definatly can take a hit. This is a 2nd on AJ's for rails
Old February 16th, 2004, 17:20
xj92's Avatar
xj92 xj92 is offline
bburge
If you've been off-roading in boulders enough, you'll realize that every single part is going to hit eventually, so the more ground clearance you have in each part of the vehicle the better. And the more solid your skids are the better because you'll hit them eventually. The terrain you wheel in isn't on a flat plane.
Old February 17th, 2004, 13:55
utahxjer utahxjer is offline
AJ's are tough and look good! They are easy to install as well.
http://community.webshots.com/photo/...92487726XZaYJS
http://community.webshots.com/photo/...97722041rfNjtc
Old February 17th, 2004, 14:22
XJClassic XJClassic is offline
NAXJA Member #1086
I use Tomken's... about $250.00 www.tomken.com
Old February 17th, 2004, 14:29
Atl XJ's Avatar
Atl XJ Atl XJ is offline
Originally Posted by utahxjer
Those do look good.
Old February 18th, 2004, 17:06
Silver Bullet Silver Bullet is offline
Check out www.detoursusa.com for some rock rails that bolt on easily and are rock solid. They can also be welded for siffening up the unibody.
Silver Bullet
