Old January 30th, 2018, 08:06
wgregt's Avatar
wgregt wgregt is offline
where to find window regulators 88 XJ etc
Looks like I'm in need of window regulators on all four windows on my 88. Also window seals (are they the same thing as "whiskers"? Are "whiskers" part of the same part?). The dealer says the regulators are no longer available (which is great b/c I'm sure they are overpriced) but was wondering....where would you guys go to find them? I'm only thinking boneyards, which is a PITA.
Old January 30th, 2018, 11:45
old_man's Avatar
old_man old_man is offline
Re: where to find window regulators 88 XJ etc
Check Rock Auto. Look under interior. The motorized regulator complete runs around $96 PLUS shipping.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old January 31st, 2018, 05:06
cruiser54's Avatar
cruiser54 cruiser54 is offline
What's wrong with yours? Power or manual?
Old January 31st, 2018, 15:29
old_man's Avatar
I ran across another place that had the original MOPAR ones for less. If I can find it again, I will post it.
Loveland, Colorado
Old January 31st, 2018, 16:02
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
I revived mine by filling the plastic(?) tube that the steel wire coil is stored in, with PB Blaster, and cycling the window up and down by hand They tend to rust and stick in the tube. Years later I replaced the side (vertical) slide guides and the outer, lower, wiper blade that were all grabbing and sticking to the window.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 31st, 2018, 18:19
lawsoncl lawsoncl is offline
I just recently fixed my manual windows. Ended up drilling a small hole at the top of the metal tube and squirting in some trans fluid. Works real smooth now. Still need to replace the side felt guides and bottom wiper at some point - getting too much water in the doors.
Old January 31st, 2018, 19:31
cruiser54's Avatar
You guys are on the right "track".
Old February 1st, 2018, 11:01
wgregt's Avatar
Ok thanks for the leads! I'm on it!
Old February 1st, 2018, 11:02
wgregt's Avatar
Mine are power, not manual. The windows barely move at all. Many times they will go down, and I have to pull the glass back up by hand. The rears have not been down in....10 years or more? But man, it's hot in there (in CA) till the AC gets going...
Old February 1st, 2018, 17:28
cruiser54's Avatar
You could probably fix all that by lubing the regulators........
Old February 1st, 2018, 17:46
Ecomike's Avatar
NAXJA# 2091
I had the same problem, I had to replace the side vertical guides (they were shot) and the wiper blade/trim part at the bottom of window opening. Window was binding on them all.
Old February 17th, 2018, 20:24
wgregt's Avatar
Yep. That would help me too. Any idea what you paid for all 4 window seals and all 4 "whiskers" at the bottom? Get them from a dealer? Online aftermarket?
Old February 17th, 2018, 21:58
Ecomike's Avatar
NAXJA# 2091
I got mine from a junk yard
Old February 21st, 2018, 15:41
shanesaw shanesaw is offline
TeamCherokee.com has new regulators as well as door seals and wipes.
Window regulators? Talyn OEM Tech Discussion 10 February 16th, 2015 09:35
Window Regulators! 1ATony Vendor's Specials 0 December 29th, 2011 13:12
97-01 window regulators JEEPZZ For Sale: Private Party Only. XJ ITEMS ONLY 1 April 29th, 2005 11:25
Window Regulators cguthrie OEM Tech Discussion 9 October 27th, 2003 08:10
Window Regulators HB86XJ OEM Tech Discussion 3 May 17th, 2003 19:50
