Old December 6th, 2017, 14:51
Aversnell Aversnell is offline
No start until CEL and GEN lights appear
96 XJ 4.0 RWD auto. 160k.
First turn of key to ON: no lights in info panel except BRAKE (brake is not depressed), START gets crank but no start.
Second turn of key to ON: no lights in info panel except BRAKE, START gets crank but no start.
Third or fourth turn to ON: GEN and CEL lights flicker dimly into view, START gets crank but no start.
Some crank later: if I wait for GEN and CEL to come on strong at ON, then wait until they clear (leaving only BRAKE light), THEN turn to START, she starts. Sometimes stepping on the brake helps.
Any ideas? Also my gauges are dead but I donít know if thatís related.
Iíve done generator, cleaned/tightened grounds, replaced fuel pump/regulator, filter, battery, plugs, cap, rotor, TPS, IAC, CPS, NSS, ignition switch (x2), ignition coil and more. Swapped relays around and checked fuses a million times. Getting ready to set the thing on fire. Runs like a dream once she starts, but takes her time starting.
Old December 7th, 2017, 11:29
rsadler rsadler is offline
Re: No start until CEL and GEN lights appear
Intellect had the same issue and it turned out to be the ECM. Look for his threads.
Old December 8th, 2017, 14:24
Good call.
For anybody whoís watching... it was the PCM. Slapped in a reman PCM and she starts right up. Still donít have gauges. Stumped on those.
Old December 17th, 2017, 15:47
flyerstump flyerstump is offline
I just fixed my buddies 95 2.5l wrangler that had the same problem. Crack your ECM open and replace the 220uf 25vdc capacitors. His had three. You can find a tutorial on youtube. I did it for $4 in parts. Biggest p.i.ta. is getting all the ballistic gel off the circuit board so you can desolder/solder parts out and in bit worked like a charm.
No start no crank no lights no power! hell OEM Tech Discussion 10 March 18th, 2013 07:43
no start, running lights come on when you turn the key etc XJRunner OEM Tech Discussion 2 April 26th, 2012 01:24
Lights flashing no start:confused: mattgwozdz OEM Tech Discussion 2 August 29th, 2009 15:50
no start..no lights..no nothing wishihad1 OEM Tech Discussion 8 November 30th, 2007 08:19
lights flashing and NO START.... hangubus OEM Tech Discussion 1 March 20th, 2005 19:04
