Old November 19th, 2017, 21:57
Heavyopp Heavyopp is offline
Custom battery box
So I had some rot repair under my OEM plastic battery tray -- I cut out the rot and welded in new -- decided it was time for a custom aluminum box
This is the nasty that I cut out
No pictures actually doing the repair but here it is finished and coated in POR15
Built my new battery mount/box out of 1/8th aluminum sheet
decided to play with my new TMR customs dimple die set
Designed around this battery from Sams club -- It's made by East Penn and is a Deka intimidator AGM clone
Test fit the box in the jeep
It's been pulled for paint, Still need to make the top battery hold down strap -- Hope to get it finished this week
Old November 20th, 2017, 05:21
ehall's Avatar
ehall ehall is offline
Re: Custom battery box
Looks good, I have a hole under mine need to patch
my '91 beater rebuild
Custom Battery Cables. poorboyjohn Modified Tech Discussion 22 August 11th, 2006 22:26
Custom battery cables JnJ Modified Tech Discussion 16 January 28th, 2005 14:56
custom battery cables... red91 Modified Tech Discussion 22 December 15th, 2004 15:24
Whats killing my Battery ?? dual battery system MACH90XJ Tow Rigs and Trailers 3 July 27th, 2004 16:26
