Old November 15th, 2017, 10:24
coldcdn coldcdn is offline
Security system quick question
Quick question about my 1992 limited Cherokee the factory security system when I reconnect the battery is active lights are blinking Etc read through all the post found that there is a green wire with an orange Tracer that you permanently ground to disable the system permanently. On which connector do you splice in to the green wire with the orange stripe I have one on my main black cluster connector and I also have a green with an orange stripe on the connector that goes into my door. I also looked under the dash and I do not have a maroon connector going into anything.
Old November 15th, 2017, 17:41
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Wish I could help, our 91 acted like it had an alarm last time I disconnected the battery, disconnected and reconnected the battery again after a minute and it was fine after that. No idea if we have an alarm and its never done this before in 15 years of ownership. Although the build sheet jeep has on line said we had keyless entry, weve never had a key fob either .
Home security system DSC Alexor 2-Way Wireless Panel sensors complete home system RWKHausSupply SoCal For Sale 1 February 10th, 2014 08:56
factory security system scott00tj OEM Tech Discussion 6 February 19th, 2011 13:50
EVS II Security System Install Ice_Man OEM Tech Discussion 7 June 18th, 2007 10:10
OEM EVS II Security Plus System 2000XJSPORT OEM Tech Discussion 7 November 15th, 2006 08:59
2000 XJ quick audio-system question brtb OEM Tech Discussion 2 August 28th, 2004 15:29
