Old November 12th, 2017, 08:51
01blkxj 01blkxj is offline
Replacing evap lines
The evap lines from the gas tank to canister are rusted away on my 01 xj i would like to ask what would be best for replacing them
Old November 12th, 2017, 10:14
RCP Phx RCP Phx is online now
Re: Replacing evap lines
Stainless would be best but aluminum is cheaper and easier to bend. I don't know if any pre-bent lines are available?
Old November 12th, 2017, 12:48
Where can I get that
Old November 12th, 2017, 21:04
Tin Man Tin Man is offline
Summit, Jegs, etc......
Old November 13th, 2017, 06:49
Classic tube is another source.
http://www.classictube.com/catalogse...gths+of+Tubing
Old November 13th, 2017, 17:22
Waynerd Waynerd is offline
I was just researching this and I found prebent lines. Not stainless but same as factory. I'll see if I can find them again.
Replacing AC condenser lines ctnsupra1 OEM Tech Discussion 8 May 9th, 2011 08:45
Replacing rad, tranny lines, anything else? dutchjeep OEM Tech Discussion 10 August 20th, 2007 08:31
Replacing vacuum lines Highlander OEM Tech Discussion 4 May 20th, 2006 19:50
Replacing Brake Lines MudslinginXJ OEM Tech Discussion 0 March 21st, 2005 09:44
For anyone replacing tranny cooler lines.... jeepguy97 OEM Tech Discussion 4 February 23rd, 2005 11:21
