Old October 31st, 2017, 21:45
Willie474747 Willie474747 is offline
Only one headlight working
Only one headlight working . Tried 2 new headlights and still doesn’t work. Any ideas what to check next? Thanks
Old October 31st, 2017, 22:31
Heavyopp Heavyopp is offline
Re: Only one headlight working
ground at the bad headlight would be my 1st thought
Old November 1st, 2017, 05:44
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Broken/separated wire at the back side of the plug. Maybe dirty contacts in the plug.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ • 4.0 • AW4 • 231 • Modified
'87 MJ • 4.0 • AW4 • 231 • D-44 • Stock-ish
SoCal Chapter VP
Old November 1st, 2017, 09:13
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
On a 91 XJ I had the drivers side ground break at the plug. Soldered in a replacement socket to fix it.
Other place to check is the headlight harness plug near (sort of underneath ) the air filter housing and computer on the 1991-2 XJ
Old November 8th, 2017, 19:44
Went to use high beams and both work. Not a plug issue or a ground issue but was a faulty 10a fuse low beam relay in cabin that had blown out from trying HId headlight kit. Problem fixed with a $1.00 part. Go figure
one headlight barely working? ptimhere OEM Tech Discussion 9 July 21st, 2017 07:01
radio quit working after headlight switch replace max419 OEM Tech Discussion 3 August 25th, 2011 11:39
headlight ? #2 f-a-t-b-o-y OEM Tech Discussion 8 November 17th, 2008 18:40
headlight PN shimmy OEM Tech Discussion 4 July 2nd, 2004 23:56
Headlight Harness Upgrade- Need to find stock headlight relay XJEEPER Modified Tech Discussion 5 September 26th, 2003 13:26
