Old October 19th, 2017, 20:51
jeeperguy21's Avatar
jeeperguy21 jeeperguy21 is offline
Knuckle rotation questions - caster change
I am about to dive into the process of rotating the axle C's to get a better caster angle. Prior to making any adjustments, I measured the current angle on both the driver and passenger sides and am getting different measurements. The passenger side shows 1.1 degrees and the driver side shows 2.3 degrees, shown in the links below:
https://www.dropbox.com/s/0ldsdayjsd...27.50.jpg?dl=0
https://www.dropbox.com/s/3cyuq4oxwp...27.04.jpg?dl=0
Couple of questions:
1) Am I measuring this correctly?
2) Should I try adjusting the control arms to have the caster match on both sides before I start grinding away?
Old October 20th, 2017, 07:38
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Knuckle rotation questions - caster change
Are you measuring from a raw casting surface, or from a machined surface ? I would be rough measuring caster from the top of the ball joint, or better yet, with the outer C and ball joint removed, measure from the flat machined surface at the ball joint opening. Some variation in caster is certainly possible.
I would be setting the caster angle in only relation to the axle housing, and not in relation to the control arms or the Jeep.
If you are using short control arms, minor caster adjustments can be made with caster shims on the frame side of the control arm.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old October 20th, 2017, 07:56
I was measuring from the surface right next to the top of the lower ball joint. As I was trying to figure out the best place to measure the caster, I also got a measurement from on top of the top ball joint, which had the passenger caster at 1.8 degrees. I don't recall what it was on the driver side as I didn't snap a pic. Here's a pic of the passenger side:
https://www.dropbox.com/s/cpodda8913...23.49.jpg?dl=0
Since some variation in caster is possible, should I make it the same on both sides before I adjust it, or just proceed and make them the same afterwards? I have long control arms that are easily adjustable. I would just need to decide if I should make the top shorter or the bottom longer on one side during the adjustment.
Old October 20th, 2017, 09:05
Tim_MN's Avatar
Since you are going to change the caster, the current measured caster numbers, nor any side to side variance, do not matter, they are only used as a reference. Measure, or assume that the frame side mounts are equal distance from the axle, then make sure the adjustable control arms are close to each other in length, and get to work.
Rotate the C's in relation to the axle housing.
Old October 20th, 2017, 09:12
Sounds good. I plan on rotating both sides so that they are at 8 degrees. I'll make sure the arms are the same length on both sides and then go for it.
Not looking forward to this project, but I'm looking forward to the end result.
Old November 22nd, 2017, 08:46
I started grinding away on the welds holding the axle C's on the driver's side. I must not have enough of the weld ground away because I can't get it to rotate with a BFH. I don't want to grind too much into the axle tube, so I'm looking for a second opinion on where I need to focus my grinding efforts. Here are some pics:
https://www.dropbox.com/s/3ig0sl5qz4...56.40.jpg?dl=0
https://www.dropbox.com/s/ue6egaz7ys...53.34.jpg?dl=0
https://www.dropbox.com/s/b0426lvs50...53.47.jpg?dl=0
https://www.dropbox.com/s/xae8xyomoe...55.39.jpg?dl=0
https://www.dropbox.com/s/qoxy4hhzys...55.55.jpg?dl=0
Old December 4th, 2017, 14:27
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
I PMed you the link to my knuckle rotation thread, but I'll share it here as well. Too bad Photobucket killed my picture links, but there are good descriptions of each step, which should help.
http://www.naxja.org/forum/showthrea...ation &page=4
Speak the Truth-Question with Boldness-Speak without fear.
Old December 4th, 2017, 15:15
I read the thread in great detail prior to reaching out to you. I was able to see the pics using a Chrome extension that makes them visible. I'm hoping for some advice one where I currently stand. In my opinion, I think I've ground sufficiently, but the C's won't budge. I'm putting quite the mark on them as I've pounded them with a sledge.
I'm wondering if you can see anything obvious in the pics to point me in the right direction. Is it more grinding into the axle tube that I need to do, try to focus my efforts onto the C's themselves, or something else? The last thing I want to do is to grind a hole into the tube by attacking this the wrong way.
Old December 4th, 2017, 21:31
donthelegend donthelegend is offline
Did you cut fairly deeply into the inner C or stay farther out (so you were grinding more of the weld rather than the metal of the inner C)? I see a couple spots that look kinda like the end of the weld but it's hard to tell. The best way I can describe it is that it looks like a small "tear" at the transition point. I'm going to try to mark up a couple of your pics and I'll post them in a minute.
Edit:
Old December 5th, 2017, 09:16
XJEEPER's Avatar
NAXJA Member # 13
It's difficult to tell from your images, if you have removed enough of the weld/knuckle to allow the knuckle to rotate freely on the tube, but suffice to say that if the knuckle is not rotating with the application of force from your hammer, then you need to remove more material.
It appears to me from the image 18.55.39, that you haven't sliced into the lower-rear section of the knuckle enough to cut through the weld.
I recall shaving about 1/8"+ from the inner knuckle surface, in order to get behind the factory weld. This required several cutoff discs and a right-angle die grinder to accomplish.
http://i173.photobucket.com/albums/w...I/100_2964.jpg
A small section of weld will prevent the entire knuckle from rotating.
Old December 5th, 2017, 09:42
Thanks for looking at the pics, guys. I now think that I attacked the weld much more so than the inner C. I don't believe I really got into the inner C much, which is likely what is causing my inability to free it from the axle tube.
Next time I have a chance to grind, I will focus most, if not all of my efforts on shaving down the inner C to try and free it up. I'll let you know what the outcome is.
Old January 29th, 2018, 15:02
I am pleased to report that I was able to get my axle C's to rotate after grinding further into the C's. I've got them rotated to 8 degrees, which will be a night and day difference compared to them being a 1 degree previously.
I need to replace my ball joints as at least one of them is confirmed to be bad on the passenger side. It seemed to fail while I was trying to remove the knuckle. You can see a lovely clip of what this failure looks like here:
https://www.youtube.com/watch?v=Q7uAYoaAYtU
I need the help of someone to weld these puppies back into place. I have 3 neighbors that weld, but I don't fully know their level of competency. I have considered hiring someone on the local online classifieds, but haven't pulled the trigger on that yet. Any local volunteers? I will pay handsomely with a free meal, internet points, or cash. I have a 240V outlet in my garage. Needing someone that is mobile and can come to me.
I took two vastly different approaches to the driver and passenger side. I did the driver side first and thought it would be best to completely grind off the original weld. This means that this side will need to be built back up to the thickness of the original weld: https://www.dropbox.com/s/7tcalcup5u...49.46.jpg?dl=0
I wised up after the first side and used only a cutoff wheel and sawzall on the passenger side which left most of the original weld in place, but I don't know if the space is wide enough to get a good weld in place: https://www.dropbox.com/s/oycj9kakdc...48.56.jpg?dl=0
I want to make this as easy as possible for whoever I end up getting to do this. Thoughts?
Also, if anyone has a recent opinion of ball joints, feel free to share. It seems like the common theme I'm finding is that Moog joints aren't what they used to be, Spicer is a safe bet, and other brands are hit and miss.
Old January 31st, 2018, 15:48
Bump:
TLDR: Looking for a local to weld my rotated axle C's into place.
Also wondering what the latest opinions are on ball joints. Need to replace my Moog joints, but don't know if Moog is still a solid option.
Old January 31st, 2018, 18:28
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Word on the street is to stick with Spicer.
A million years ago, when I was in welding class (I'm no welder), when welding heavy stuff, the rule of thumb was to grind a "V" such that about 1/2 the thickness was ground away. This was so you get get full penetration to to opposite side of the material. From your description, you likely will need to grind some "V" in the work. A weld has no strength on any part of it that doesn't penetrate completely through.
David Bricker / SYR - YYZ
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2019
Not a member? Become one today, and help support YOUR club.
Old January 31st, 2018, 21:57
chasdb's Avatar
chasdb chasdb is offline
Grind the passenger side weld down to the tube. Pull the axle out completely so the knuckle can be welded flat when the axle is positioned vertically and cooled, then flipped and the other knuckle done.
Knuckle rotation contemplation XJEEPER Advanced Fabrication and Engineering 87 September 20th, 2011 10:26
will caster change effect camber too? Shorty Modified Tech Discussion 10 November 24th, 2008 16:02
tube rotation/caster adjustment? 1998xj1985 Modified Tech Discussion 4 October 19th, 2006 13:50
Check my figures on knuckle rotation please 87xjco Modified Tech Discussion 10 July 18th, 2006 15:30
D44 Knuckle Rotation Question slvr98svt Modified Tech Discussion 7 August 25th, 2005 15:03
