Old October 26th, 2017, 06:12
Mikep_86441 Mikep_86441 is offline
Re: Going Through a Beater XJ 4.0. Oil Pan Still Stuck !!
The pan at the deepest part has been side loaded with pressure from a bottle jack for a few days now. Pan still won't come loose. I'll start on removing the head for now since I'm convinced that there is a busted piston.
Here's the bottle jack video:
https://youtu.be/ynP2juTxySQ
Old October 26th, 2017, 06:40
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
You sure you have all the oil pan bolts out? Even the ones that look like studs are bolts
I have had some tough ones before but never that tough.
Old October 26th, 2017, 08:16
BenWheelin BenWheelin is offline
Originally Posted by Green XJ Jeep View Post
You have far more motivation than i do.
I spent the 100 on a spectre cu1193 rad and converted to open cooling.
I replaced the Spectra every year, three years in a row, before I gave away the receipt and went to Murray. POS shaved a lot of miles off a good engine at one point because it sat a while and went downhill.
If ever you should have an overheating problem but can't find the fault, it's probably that radiator. Cap flange is weak and dumps pressure to the reservoir. Maybe it only overheats with the AC on or at higher speeds.
That's the Spectra "Premium" for you.
Old October 26th, 2017, 08:22
Somebody must have been tired of oil leaks and glued it with something fierce. I'd cover it with a 2x4 and smack that against the side with a good sized hammer. Given the bottle jack in place, I'd be looking for a new pan to go back together with in case this one gets destroyed.
Old October 26th, 2017, 18:07
I think the oil pan gasket is factory original to 1988.
Used a 2x4, a sledge, and a huge rubber mallet. Didn't budge.
Old October 26th, 2017, 18:10
Positive.
Been pulling pans a long time without any damage to them. Might be this pan is the one I trash.
There was a guy out there that used his truck and a chain to pull his 4.0 pan off. It worked.
Old October 26th, 2017, 18:15
Today I gave up on the oil pan so I started pulling the head.
Old November 3rd, 2017, 19:07
Re: Going Through a Beater XJ 4.0. The Head is Off !!
Not only did the head come off today, but I started to inspect it.
The head will get a 3 angle valve job once it's disassembled.
Still can't get that glued on oil pan off.
Head Removed: https://youtu.be/KdE2I31rqcs
3 angle valve job start: https://youtu.be/weJn3OmLO_U
Old November 7th, 2017, 06:00
Re: Going Through a Beater XJ 4.0. Head Disassembly.
Something odd found under each intake valve. https://youtu.be/eMlgGNi5LB0
Old November 7th, 2017, 18:38
Re: Going Through a Beater XJ 4.0. Pitted
Close up exam of valve faces and seats find some pitting.
https://youtu.be/5DwOeRRygMI
Old November 7th, 2017, 18:41
Re: Going Through a Beater XJ 4.0. Pitted Valve Seats and Faces.
Old November 7th, 2017, 19:09
Re: Going Through a Beater XJ 4.0. Oil Pan is finally Off !!!!
Unbelievable !! I got the oil pan off of the 4.0 !!!
Here's how !!
https://youtu.be/o6qasii-0HE
Old November 15th, 2017, 18:20
The valve faces were very worn and pitted. Now they look very nice !!
https://youtu.be/jgKBsb39Nno
Old November 24th, 2017, 16:02
Re: Going Through a Beater XJ 4.0. Head Cleaned Up.
Got the head scraped off and pressure washed today. Got quite a bit of rust out of the cooling passages in the head. Now it's ready to have the seats cut with a 3 angle valve job. Maybe even back cut the intake valves a bit for more flow.
https://youtu.be/sODYCv7_7Po
Old November 26th, 2017, 14:42
Re: Going Through a Beater XJ 4.0. A head/block crack ??
I sure hope vinegar solves this rusted head bolt/block problem !!
https://youtu.be/6I6qyc5b0sI
beater! ehall North Atlantic Chapter 638 Yesterday 18:10
Beater XJ itrack Modified Tech Discussion 7 April 1st, 2011 09:02
Who's got a Beater Rig? Letterman Sierra Chapter 10 November 6th, 2010 11:52
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 17:34
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 07:26
