Old June 19th, 2017, 17:48
eightsevenzero eightsevenzero is offline
'97 XJ steady miss?
Hey,
Just bought a bone stock '97 with 4.0 and manual tranny, 147K on the clock. It idles at steady at 700 rpm but has a miss hiccup every second or so. Also when driving you can feel it ever so slightly continuously stumble under acceleration. No codes are being thrown and it actually has good power overall. Here's a list of stuff I've done to try and fix the issue:
New CPS
New Plugs, Dizzy cap, rotor, and wires
Fuel pressure test, holds 49 PSI steady
My next thing to try is maybe a can of Seafoam to see if it temporarily helps. Any ideas? Thanks!
Old June 19th, 2017, 19:19
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: '97 XJ steady miss?
Is it getting up to operating temp?
My 96 was doing the same thing when the thermostat stuck open. New thermostat and problem solved.
Old June 19th, 2017, 20:38
Yes, always comes up to about 190-200.
Need help: engine won't run steady or idle 2T2-Crash OEM Tech Discussion 15 September 11th, 2014 18:22
Jerking at a steady speed 360_XJ Modified Tech Discussion 19 April 6th, 2013 04:52
Collision resulting in a steady radiator leak. GoBlue OEM Tech Discussion 3 February 28th, 2013 17:52
My XJ's slow but steady evoloution UNCC_99XJ Jeep Picture Showcase 7 June 9th, 2011 05:49
XJ consuming coolant at a steady rate willsmysticcobra Midwest Chapter 31 January 13th, 2011 06:45
