Old April 17th, 2017, 06:47
2T2-Crash 2T2-Crash is offline
Shifter hard to put in park
87 XJ with AW4 and roughly 4" lift, no transmission spacer blocks.
When my XJ is shifted into park it does not lock into place unless a good bit of force is applied to give it that extra bit for the ignition locking tab to click in place.
My Sister in law now owns my jeep and the quirks I know how to deal with aren't something she is used to.
Since the key can be pulled in and out of the ignition at any point my SIL fails to realize the ignition switch is not fully shut off and thus the battery dies.
What needs to be adjusted so the shifter locks in park properly?
Old April 17th, 2017, 14:02
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: Shifter hard to put in park
More than likely shifter cable needs to be adjusted. On my 89 XJ. the cable adjustment is on the driver side trans tunnel.
IIRC, pull the cable out of the bracket (carefully, there are plastic clips that hold it in), pull the sleeve back and adjust cable.
Also make sure there are no kinks or damage to cable. You can google/youtube exactly how if necessary. If you have an fsm it should tell you as well.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
For Sale: 91 AW4 w/raddesign baja shifter, nv231 w sye and novak shifter Skullver SoCal For Sale 38 November 23rd, 2009 11:39
Hard to get out of park 89toots OEM Tech Discussion 10 January 23rd, 2009 14:24
Paragon Adventure park online petition. Those who enjoy the park Should look. xjfanatc Land Use Forum 6 April 1st, 2007 23:16
WTT: WV Rare Auto Column shifter for floor shifter setup mdemic For Sale: Private Party Only. XJ ITEMS ONLY 2 July 8th, 2004 18:02
Gear shifter not staying in park BIGSLVRXJ OEM Tech Discussion 7 June 18th, 2004 16:49
