Old June 2nd, 2018, 16:26
BryanDowdy BryanDowdy is offline
Shift kit installed, now issues
I have a '00 XJ with a AW4. I installed the Transgo 340-HD2 shift kit. Now with it back together with the shifter in the 1-2 position it is 3rd gear, in the 3rd
position it works as it should (shifts 1st-3rd), 4th position does nothing feels like neutral, and Neutral, Reverse, and Park positions all work as they should.
Here's what I've done so far:
Tested all solenoids
Confirmed correct VB gaskets
Pulled the VB and double checked for correct installation of shift kit
New filter and fluid
Old June 2nd, 2018, 22:15
RCP Phx RCP Phx is online now
Re: Shift kit installed, now issues
I just went thru something similar on my 2k, have you spoke with Transgo?
https://naxja.org/forum/showthread.php?t=1147175
Old June 4th, 2018, 08:03
Thanks for the reply! After reading your thread I ended up going through the VB again and sanded any valve that didn't move smoothly. One of them must have been getting hung up, because it works correctly now.
Old June 4th, 2018, 08:47
Glad to see you got it working! It sucks to have to do it twice, but at least it'd fixed.
Old June 4th, 2018, 09:20
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Weird that this issue has surfaced so frequently. I didn't have any post-install issues with this shift kit and don't recall sanding the edges of my valve pistons.....but maybe I did?
Speak the Truth-Question with Boldness-Speak without fear.
Old June 4th, 2018, 14:56
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
it may be the manufacturing process has changed. this seems to be a new issue.
Shift issues Cody88xj OEM Tech Discussion 2 June 9th, 2017 06:52
Transmission shift issues Stevv3e OEM Tech Discussion 0 July 23rd, 2014 16:58
Shift issues catpower OEM Tech Discussion 28 January 29th, 2012 13:56
Installed a remote starter today now the brake/shift interlock doesn't work. Blaine B. OEM Tech Discussion 0 September 10th, 2006 19:20
AW4 shift issues alosix OEM Tech Discussion 1 May 4th, 2005 08:42
