Old December 7th, 2016, 22:36
zachtyler zachtyler is offline
Headlight/Running Light question
Bought my xj and the previous owner had installed some LED headlights. The headlight switch has two positions. One click and two clicks. Is the first click supposed to be the orange lights up front? I've read about running lights on xjs but never seen much information. When I pull it once, the headlights come on as well. And the second click just keeps everything on so nothing changes. Must be the way he wired them? Anybody know how to fix?
Old December 8th, 2016, 05:23
ID96XJ ID96XJ is offline
Re: Headlight/Running Light question
The first click should be marker and tail lights.
Unless yours has day time running lights?
Old December 8th, 2016, 06:31
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Never had daytime running lights.
PO installed headlight harness for those LED lights incorrectly.
Old December 8th, 2016, 08:31
Any idea where I should look for the mistake?
Old December 8th, 2016, 08:36
cal's Avatar
cal cal is offline
give us pictures of the wiring to the headlights, lets see if its an aftermarket wiring harness.
If it is, should be fairly simple.
Old December 8th, 2016, 09:17
RCP Phx RCP Phx is online now
I never had DRL's in 15yrs. as soon as I installed LED's now I have them! There was no re-wiring, it's all stock.
Old December 8th, 2016, 11:14
Well, just replaced a turn signal socket which was giving me some other issues. Solved them with that fix. While undoing the sidemarker, i realized it appears it's been spliced into. Now, I'm a beginner with wiring but I would assume that would cause the headlights to come on whenever the parking lights receive power through that wire. It is an aftermarket harness. Has a couple relays, and the wire goes from headlight to headlight. Also has one wire going to the battery positive terminal. Pics attached. I'm assuming the issue is coming from that splice into the sidemarker.
Old December 8th, 2016, 11:15
cal's Avatar
cal cal is offline
thats pretty much it. its getting signal from the side marker and not a headlight.
you need to either splice into a headlight wire for that signal, or get a real headlight harness.
cal's Avatar
cal cal is offline
https://www.amazon.com/Putco-230004H.../dp/B001P29X4G
Old December 8th, 2016, 11:19
Thanks, Cal. Sorry for the noob questions I just don't have anybody around to help me. So, this new harness will work with my upgraded headlights, right? Because I believe they are HID.
Old December 8th, 2016, 11:23
90xj06's Avatar
90xj06 90xj06 is offline
yes it will work. that harness just uses t he head lamp switch to toggle the relay and then pulls power from the battery to give the best connection.
Old December 8th, 2016, 11:26
Thanks, a ton. I appreciate the help, man! I just gotta figure out the wiring because on the back of those boxes in the picture, it's got all kinds of connections plugged in.
Old December 8th, 2016, 11:27
cal's Avatar
cal cal is offline
depends on your headlights but should yes
Old December 8th, 2016, 11:36
You see the connections on the back of the silver box? I'm not sure those will be compatible with the new harness. I've just got no experience with wiring. Might be easier for me to buy an entire new set that comes with a harness.
Old December 8th, 2016, 11:37
cal's Avatar
cal cal is offline
they are pretty much all the same. fairly standardized.
where in california are you?
Strange Headlight and Parking Light Issue RenegadeStang OEM Tech Discussion 2 March 6th, 2016 07:18
running light/interior light issue Backroads OEM Tech Discussion 7 April 29th, 2011 15:51
My Headlight/Interior Light upgrade Mr Clean 1 OEM Tech Discussion 2 March 22nd, 2010 16:26
Headlight\fog light switch 88 Wagonman Modified Tech Discussion 5 November 30th, 2008 09:07
Headlight/Signal light problem godplayer OEM Tech Discussion 7 November 20th, 2007 11:40
