Old December 4th, 2016, 18:23
ehall's Avatar
ehall ehall is offline
yoke upgrades or no
I bought a pair of TJ Rubicon D44s and looking at all the affected areas. I know I will need a front driveshaft since the D44 pinion is longer than the D30. The rear D44 has a 1330, wondering if I should get one for the front. But then the 1310s on the double-cardan shafts will be the weak link, and its a pain to rebuild those, so maybe upgrade the NP242 yokes and find a 1330 double-cardan CV kit. Lot of work... not necessary? If not then why does the rear have a 1330? First time into this part of the forest, any info appreciated
my '91 beater rebuild
Old December 4th, 2016, 18:52
VAhasnoWAVES VAhasnoWAVES is offline
Re: yoke upgrades or no
according to tom woods... 1330 yields you minimal strength over a 1310, and a loss of operating angle. their recommendation was to stick with 1310, or go 1350.
you can obviously find conversion joints to get you by in the mean time until you decide what you want to do. but buy a spare if you plan to wheel, cant count on someone having the proper conversion joint. custom shafts can be built with what ever you want. or use the spicer PDF to find something that fits what you need.
Old December 4th, 2016, 19:47
ehall's Avatar
yeah I have short-term figured out, thinking about long-term stuff now
Old December 4th, 2016, 21:23
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
stay with 1310's, for your rig I see no need to go bigger, ive gotten 2 broken 60 shafts and have yet to break a 1310
Old December 5th, 2016, 04:39
ehall's Avatar
Hmm. I've seen a couple of broken 1310 joints and yokes, but I think they had other problems first, like rusted cap bearings, or a driveshaft slip joint seized up. I lube my junk every oil change to flush water, never had any of those problems. I twisted a driveshaft from the V8 WJ in half, joints are still fine. You might have a point there.
Old December 5th, 2016, 05:14
ROBZ95Xj's Avatar
Proper gearing in the axles helps to, takes the stress off the ujoints, using quality ujoints helps too
Old December 5th, 2016, 10:47
ehall's Avatar
One of the local buggy guys said the same thing, twisted a 1/4" DOM driveshaft but didn't break the 1310s on it.
Think I will downgrade the rear D44 to 1310 to simplify spare trails
Old December 5th, 2016, 12:29
srb531 srb531 is offline
the 1310s have always been good to me, btw where are you in so md.? im in annapolis.
Old December 5th, 2016, 16:29
ehall's Avatar
I'm in St. Mary's County
Old December 8th, 2016, 13:25
freerider15's Avatar
freerider15 freerider15 is offline
If you're going to replace yokes, I highly recommend going with flanges.
I'll be putting flanges on everything I can from here on out.
FAR better than farkin' yokes
XJ Buggy On Tons
Old December 8th, 2016, 19:11
ehall's Avatar
That's a good idea. Do you know which flanges work with the D44 pinions?
Old December 9th, 2016, 08:22
ehall's Avatar
Looks like there are Toyota-flange conversion parts that will work. On the axle side there are some 26-spline to Toyota flange adapters, eg Nitro YOKD44-TOY-26, or PartsMike 1B-3051A, some others. On the driveshaft side I would need 1310 to Toyota flange adapters, looks like Spicer 2-2-479 is the one people use. That is for the axle side, have not looked into the transfer case side since I would probably keep those on the bolted CV yoke / centering ball anyway
Old December 9th, 2016, 08:33
I got my flange from High Angle Driveline.
I have mine on the T-case side in the rear.
At the axle end is where it will give you the most benefit (not mashing the yoke when it's stuck on something).
The t-case end it more for additional strength and ease of install.
Going to flanges isn't the cheapest, but after having it on one end...I want it on them all
XJ Buggy On Tons
WTB: Slip yoke for external yoke transfer case Talyn SEC For Sale / Wanted Forum 0 October 21st, 2014 07:23
Flange style yoke or standard yoke? MG2000XJ Modified Tech Discussion 2 May 30th, 2009 21:52
U-joint snapped tab on yoke off, new yoke needed? fattmann OEM Tech Discussion 8 May 27th, 2009 07:38
np 231 front output yoke to use as dana 30 yoke? rockwerks Modified Tech Discussion 11 May 3rd, 2007 14:51
flange yoke connecting DS and pinion yoke Shomsky462 Advanced Fabrication and Engineering 23 May 14th, 2006 18:19
