Old November 6th, 2016, 16:56
Brian82 Brian82 is offline
Hack n Tap w/3" lift
Ive run a hack n tape SYE with 4.5" lift before using a XJ front drives shaft in the rear. Anyone done it with 3" Lift or will a stock xj front shaft be too long? and that is obviously cutting off as much remaining shaft as possible from the xfer case.
Old November 6th, 2016, 17:45
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Hack n Tap w/3" lift
H&T at 3 inches can be done. The stock driveshafts IMO are a bit too long for H&T at 3 inches of lift. I would try to find a slightly shorter driveshaft. The FAQ's has a driveshaft length thread. Around here the driveline shop charges $75 to shorten and balance a driveshaft, which is still cheaper than a custom made drive shaft.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old November 7th, 2016, 04:28
Yeah roger that, i do have a shaft shop near by, i'll do some measuring and still use a front shaft and have it shortened..
Old November 7th, 2016, 08:58
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
I know when I did my h&t I was at 2.5" if lift but I also cut them tcase shaft down to the lowest safe length which was 1.25". Ran a standard front shaft and didn't have issues
Old November 7th, 2016, 17:37
Thanks for the input. Might aswell try the stock length shaft anyways
Old November 7th, 2016, 19:00
Dragonlich1961 Dragonlich1961 is offline
if an stock auto shaft is to long try a stock manual shaft, a manual tranny and t-case combo is shorter than a auto combo
Old November 8th, 2016, 04:52
Roger, that . I never looked into the differant shaft lengths before. Probably harder to find though im thinking. Thanks
Old November 9th, 2016, 17:06
Pinion angle/ leaf shims size used with your 3" hack n tap setup? 2-4? 4 degrees im guessin..maybe
Old November 9th, 2016, 22:07
None, I did a bastard pack rear leaf and shackle relocators. Never got any vibes
Old November 10th, 2016, 14:46
Old November 15th, 2016, 11:57
nicpaige nicpaige is offline
I did H&T using a stock drive shaft on mine with 3.5" lift no problems.
Old November 22nd, 2016, 15:08
Looking for a starting point here since ill be doing leaf spring shims myself and ordering them online. Suggestions on what degree shim i could start with. 3" lift with hack n tap SYE kit. Im thinking a 3-4 degree shim. I do have some vibrations with the zero pinion angle stock setup.
Old November 22nd, 2016, 17:50
Did mine & its vibrating . time to shimm a roo
Old December 9th, 2016, 17:14
pjanda1 pjanda1 is offline
I'm not sure why you'd do a hack-n-tap if you are willing to pay to have a driveshaft shortened. It would be the same price (or cheaper) and better to toss a real SYE in. SYE kits are under $200 and only take a couple of hours.
Paul
rusty's 6.5" coils/control arms and RE hack n tap 962door MWC For Sale/Wanted Forum 9 February 24th, 2012 18:45
hack chopped 2dr on craigs, 36" tires w/no lift streetpirate NorthWest Chapter 12 May 29th, 2011 19:09
| RE 4.5" Super-Flex for ZJ | RE Hack N Tap | RE CV DS | swbooking SoCal For Sale 3 July 17th, 2009 09:07
Cheaper Hack n Tap MINUS THE HACK XJoshua Modified Tech Discussion 8 July 17th, 2007 06:36
Front Drive shaft, hack and tap kit, 2" spacers red_01_xj For Sale: Private Party Only. XJ ITEMS ONLY 4 December 5th, 2006 21:08
