Fringeless
- Roswell, NM
I am in the process of doing a write up of an mS3 install to post here and on Jeep Strokers Forum. It is installed on a 92 running a 4.6 stroker @ 9.7:1 with stock trans, gauge and a/c function. However, I am I have run into an issue. Before I put in the MS3, my PLX devices gen 4 AFR module and gauge quit working. While under warranty, PLX dicked me around via email saying that the module was fine and that I needed a new O2 sensor. Well new sensor did not fix problem. I opened the module to find a burnt transistor. I contacted them to show them my finding. Richard @ PLX told me that since I opened it, the warranty is void, and that I must send it in for repair @ 99$ or buy a new board at the same price. I told him that I would like the component numbers (cannot read numbers burned off) so that I could repair the board myself. Initially, he agreed, but later responded
"Due to proprietary reasons, I am not able to give schematics or any information regarding the build or components used on the board for the SM-AFR or any products. I do apologize Steven, I was not aware of this policy until connecting with the tech. I tried, but unfortunately I can not obtain them nor give them out."
Does anyone have the gen 4 PLX module, I just need a good high res close up of that sucker so that I can replace a few resistors and the transistor Q1? Asking for help. :skull2:
