Old September 28th, 2014, 14:52
Mrbreeze824's Avatar
Mrbreeze824 Mrbreeze824 is offline
Installing extra 1.5" of lift!!!!!
Hey guys got a 3.5" RE super ride lift on my 99. Found a deal last week on 1.5 coil spacers and extended shackles. My question is what else will I need to do after I install. Jeep already has a SYE and adjustable trac bar. Some one told me I may have to shim the rear end, but I thought the shackles rotated the rear end a little. ?????
Old September 28th, 2014, 15:20
IdahoEagle IdahoEagle is offline
Re: Installing extra 1.5" of lift!!!!!
Why are you looking to go taller? Are you wanting to install bigger tires or...?
Old September 28th, 2014, 16:04
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
What else do you have installed ? Longer and/or adjustable Control arms and control arm drop brackets would be an excellent idea if you plan on driving much. Will the shocks be long enough ? Shims will probably be needed.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old September 28th, 2014, 16:27
md21722 md21722 is offline
Longer shackles will rotate the pinion up. I believe its roughly 1 degree for every inch the shackle is longer. Shackles can screw up your leafs. I believe different springs or shackle relocation brackets are better solutions.
Old September 28th, 2014, 17:33
XJRN XJRN is offline
How do shackles screw up leafs? How many people do you think still have stock shackles?
Old September 29th, 2014, 03:31
Sorry guys. Yeah wanting to go a little taller, and I forgot to mention the lift came with shocks. I have the control arms that came with the 3.5" lift installed as well.
Old September 29th, 2014, 13:17
Lift shackles change the leverage on the spring and make the weak stock leafs fail very quickly. I had a slight positive arch on my leafs, installed 2" lift shackles, just commuted for maybe 3 days before the springs went full on negative... I built an AMC/Jeep bast are pack from the pack I built for my Wagon and put the stock shackles back on, I gained an inch over where the stock springs were with 2" shackles before they killed the springs...
Old September 29th, 2014, 13:18
And why are you wanting to go taller?
any tips for installing a rustys 4.5" lift? cptstoney Jeep Comanche MJ (1985 - 1992) 11 April 18th, 2014 10:21
weird noise after installing 4.5" RC lift JeepCherokeeGuy99 Modified Tech Discussion 6 May 14th, 2009 21:11
how to add extra inch or two to a RE 4.5" lift vtechthis Modified Tech Discussion 16 October 15th, 2007 04:20
installing a teraflex 2" lift.. Mopar It Modified Tech Discussion 8 May 1st, 2007 12:21
installing RE 1.25" lift shackles BUT borla exh. in the way CaptTrev Modified Tech Discussion 3 December 12th, 2003 13:47
