Old September 28th, 2014, 14:31
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Brake lines.
So I've been getting mixed info on getting longer brake lines, I'm finally putting my 3.5" lift on and want to do the brakes as well. Now I've heard YJ lines work front and rear but the 91' and 94' front lines are shorter than a xj as far as the description goes from autozone. BUT A 89' YJ front lines are 3" longer than a xj at 19" length. But now my question is rear brake lines. Are a 89' rear longer? What about the Dakota rear line? I've read that for dakota you need 95'-00', I've read you need -94', I've read it needs to be 94'-96'? So which one? I'm planning to relocate and straighten my brake line for the time being to get by but would like to know exactly what front and rear I need before ordering off rockauto.
Old September 28th, 2014, 15:17
IdahoEagle IdahoEagle is offline
Re: Brake lines.
Why not just buy new longer hoses from someone like Rocky Road? They aren't that expensive. Personally I have a local hydraulic hose outfit build them that are D.O.T. approved. They only run me $18-30 each, depending on fittings...
Old September 28th, 2014, 15:43
yossarian19's Avatar
yossarian19 yossarian19 is offline
Re: Brake lines.
Go to rockauto.com. Look up the brake lines for your model year XJ - fittings on each end, length, etc. Write the info down. The site is a PITA but it's a damned useful source for info and buying parts.
Now look at the cars / trucks you mention & compare.
Or go to Quadratec and buy a set of stainless lines.
Old September 28th, 2014, 15:54
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
Re: Brake lines.
XJ soft lines are 18' front, 13" rear.
Jeep Wrangler Left BH38862 - 20.75" Right BH38861 - 20.75"
Wrangler rear, BH38845 - 17 5/16" long
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old September 28th, 2014, 17:19
Brake lines.
Because I'm a cheap ass lol $20 a piece is expensive for me, so if I can find another vehicle factory ones that are longer than mine and have the proper fit and is cheaper will help me a ton.
Yossarian19: the problem is that not all the lines or any on the rockauto site show a length so that's why it's being a problem finding the right lines to buy
Old September 28th, 2014, 17:52
Re: Brake lines.
You weren't trying hard enough.
Rear center lists as 15", fronts are 18.25".
Not all brands list all info, so you have to click around a lot to find what you need.
Old September 28th, 2014, 18:33
Brake lines.
That's probably why then. I figured after the third one that maybe all of them didn't.
Old September 28th, 2014, 19:29
Cburb88XJ Cburb88XJ is offline
Re: Brake lines.
i believe like 94ish chevy 1500 brake lines work as well and are definitely long enough for your needs.
Old September 29th, 2014, 20:22
Re: Brake lines.
so this is the rear one you were talking about.
http://www.rockauto.com/catalog/moreinfo.php?pk=305989
now this one is from a 94' dakota.
i like that its 22" long which would be plenty but the issue I'm having is knowing if the fittings work for my 8.25. the years I posted about the dakota is why im having trouble because at one point the fitttings go from standard to metric. and Ive found no hard evidence as to what years will fit and which wont
Old September 29th, 2014, 20:46
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: Brake lines.
When I lifted my rig I called up a local hydraulic shop which used to be located in Torrance, but have since moved back east and asked them for their wrangler brake line kit. The kit is designed for a Wrangler with 4" of lift and worked perfectly for me with 6" of lift and the best part all 3 were only $27.
http://www.techna-fit.com/
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old September 30th, 2014, 00:38
stang65's Avatar
stang65 stang65 is offline
Re: Brake lines.
thats what i have on mine with my long arms but im at 5" of lift.
Old October 4th, 2014, 16:20
Brake lines.
So my front lines have plenty of slack so I don't need longer yet but I'm going crazy trying to get a confirmed answer as what year and engine of a Dakota will have a longer rear brake hose that will work! I've learned that v8 got 9.25 axles instead of 8.25 axles(don't know if their brakes lines swap over or not) and that in 97' the rear hose looks different as it has a tab to bolt it to the axle instead of having it bolt through the brake junction block.
I'm so freakin lost lol
Old October 5th, 2014, 05:52
Tim_MN's Avatar
Re: Brake lines.
The Wrangler hose is long enough, and it fits.
14 bolt disc brake conversion brake lines (or anyone using k20 front calipers) blondejoncherokee Sierra Chapter For Sale 0 August 19th, 2014 10:56
Brake Booster Options w/out flaring new brake lines??? ocalajeeper Modified Tech Discussion 5 June 25th, 2008 10:08
Newer brake lines on older brake setup? canadianwheeler OEM Tech Discussion 2 July 25th, 2007 18:09
Rear disc brake conversion- brake lines bknudtsen Modified Tech Discussion 5 September 2nd, 2004 10:37
Brake problems after installing YJ brake lines C-MuRdaA Modified Tech Discussion 0 January 15th, 2004 05:03
