Old May 7th, 2014, 13:40
slowjeep slowjeep is offline
Thumbs down 2001 engine rebuild
So I just acquired a second XJ. An 01 automatic 4wd. last registered in 2010, previous owner's title reads 180k miles from 2006 I believe. I was told the oil pump was bad on it. The previous owner started tearing it apart but only got as far as removing the oil pan. It has been sitting in dirt for a while and here's where I'm at.
I removed the engine finally after fighting with the E12 screws. Otherwise everything came out easily. I've only done top end rebuilds before so I would like some help on what to check if this was really a bad oil pump.
I will be getting some pictures of the crank and pistons tonight to show their conditions.
https://onedrive.live.com/redir?resi...t=photo%2c.jpg
https://onedrive.live.com/redir?resi...901B1CD5%21722
and how it sits for now
Old May 7th, 2014, 15:02
Tony_SS's Avatar
Tony_SS Tony_SS is offline
NAXJA Supporting Vendor
Re: 2001 engine rebuild
If you've got it out, I would just do a full rebuild on it. Double check the head and make sure it isn't cracked too.
Skull Daddy Graphics for Jeep Stickers
Mac-Ink Customs
for Jeep T-Shirts
2000 XJ Build Thread
Old May 7th, 2014, 15:07
still debating on doing a full rebuild if not necessary. I don't keep my cars for too long. checking the head tonight if I have time after compression test
Old May 8th, 2014, 07:29
Old May 8th, 2014, 09:57
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
The thing has been open to world and need a complete tear down to get all the crud out. No way we can tell anything from a few burred photos.
Might be easier to find a whole motor out of wrecking yard.
Guess you can just clean it up, change the timing chain and oil pump and hope for the best. Make sure to mark every part so it goes back it the same position, facing the same way.
It's been my experience when someone pulls the pan because the "oil pump is shot", it's usually worn bearings causing the drop in pressure.
If it cleans up without finding the bearing journals rusted, Plastiigauge them to see how worn the bearings are.
A 4.0 R&R is so much fun that I'm sure you won't mind having to pull the engine again if something more serious shows up.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old May 8th, 2014, 11:26
Tony_SS's Avatar
^ Ditto
Mac-Ink Customs
for Jeep T-Shirts
Old May 8th, 2014, 11:35
comparing prices/benefits for a junk yard motor vs rebuild.
Old May 8th, 2014, 12:33
Tony_SS's Avatar
prices for an 00-01 engine castings are a lot higher due to the 0331 head ruining engines and making them scarce.
Mac-Ink Customs
for Jeep T-Shirts
Old May 8th, 2014, 13:16
Is this Normal???
Old May 9th, 2014, 11:33
leaning more towards the rebuild. I will get be removing the head tonight and see if the engine needs any work done. Hopefully it won't need new oversized pistons.
Old May 9th, 2014, 11:36
90XJay's Avatar
90XJay 90XJay is offline
make sure to check between cylinders 3/4 for a crack on top of head. It causes coolant to get into the oil.
90 2 door sport- 6", 35's n stuff
00 4 door sport- Stock
Originally Posted by fasteddieyj View Post
118mph in an XJ? Your a braver man than I am.
Old May 9th, 2014, 19:18
Talyn's Avatar
Talyn Talyn is offline
Originally Posted by slowjeep View Post
Is this Normal???
Yes.
Start by tearing it down and cleaning it. Visual inspection on the bearings and a plastic gauge.
Old May 13th, 2014, 09:37
what water passages?
Old May 13th, 2014, 13:23
Talyn's Avatar
I don't see any problem with the head gasket aside from all the gunk, but that thermostat hole looks like something else.
New gasket:
Old May 14th, 2014, 09:02
I've been doing some youtube research on cleaning the pistons. Man are they full of buildup!!!
I should be tackling them tonight.
Engine idle problems after engine rebuild (extremely high) SicNastyXJ OEM Tech Discussion 3 January 6th, 2012 16:46
Engine Rebuild Help! CUengineer OEM Tech Discussion 25 October 20th, 2010 15:03
Engine rebuild davinci Midwest Chapter 22 March 15th, 2008 09:50
Engine Rebuild jones95xj OEM Tech Discussion 5 February 15th, 2008 08:04
Engine rebuild Boz88xj OEM Tech Discussion 9 August 31st, 2003 23:20
