Old February 12th, 2014, 08:17
MrAnderson's Avatar
MrAnderson MrAnderson is offline
Banks headers, worth the coin?
2000
4wd
4.0
156k
So awhile back my motor starting piston slapping. Well its starting to get ugly and being my only vehicle id rather replace it before it gives. ANYWAYS, im gonna have them throw some headers back in it, along with some Bd mounts and a down pipe with a flex joint, instead of the stock manifold(which im pretty sure leaks) cause i can basically get "free" labor and was checking out Banks. i know they've had issues with cracking but from what ive read, not only are they good about replacing them(very little headache involved) if it happens but also that they've figured it out now(feel free to correct me). But 400ish is a pretty penny and id like to hear if anyones got some testimony.
thanks,
Mike
i should note the heeps got aftermarket aem intake, 63mm Tb and cat back flowmaster system.
Old February 12th, 2014, 09:42
Root Moose's Avatar
Root Moose Root Moose is offline
Re: Banks headers, worth the coin?
I just bought the Banks but haven't installed yet. I don't think our Jeeps with the dual under hood cats have to worry about cracking as much. Time will tell.
Old February 12th, 2014, 10:58
MrAnderson's Avatar
what kinda price ya get from where?
you gonna do mounts and a flex pipe? basically added prevention. and from what i know those precats are lil ovens to everything around then
Old February 12th, 2014, 14:29
bentroia bentroia is offline
The Borla installed nicely on my 1990 XJ. It stopped the chronic crack/leak cycle of the stock manifold. Performance and economic (fuel) impact were un-noticeable. This was a Jeep with 31 inch tires and a 4 inch suspension system. The product was very well built and installed easily. I am not sure on the compare for your year of Jeep.
Old February 12th, 2014, 14:52
steveareno steveareno is offline
If you search Banks or headers, you will find a whole lot of very unhappy Banks owners (cracks). I have no personal experience with the header, but the Banks programmer, which I was so stupid to beleive the hype, makes no improvements in performance or fuel.
Old February 12th, 2014, 16:36
Root Moose's Avatar
I bought the header at Summit Racing with a bulk of other stuff I was ordering. Not the cheapest price but my time is more valuable than futzing with the potentials of an unknown vendor for the sake of $20 or whatever.
I am making a new 2.5" stainless S pipe and adding a flex section. I will probably place the flex section under the transmission unless I decide to put it in the custom cat section I am welding up.
I am hoping that if I do end up getting cracks it'll be in the replacement Catco pre-cat section I am adding at the same time. The Banks unit is short so maybe it won't crack if the load is taken off it.
Old February 16th, 2014, 11:42
MrAnderson's Avatar
152 views and 1 actual testimonial
Old February 16th, 2014, 12:02
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
That happens when you have the model with the bunk pre-cats..
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old February 16th, 2014, 13:11
MrAnderson's Avatar
can it jeremy
Old February 17th, 2014, 07:19
stackhousexj stackhousexj is offline
I bought a Banks header when I built my stroker. It's been on for approximately 10k miles and I've not had any issues with it. However, when I bought it and installed it, the mounting (where it mounts to the block) wasn't exactly flat. We just took a sander to it it make it level. So far I've been pretty damn happy with it, the only thing I wish it had was an O2 bung, but the stock manifold didn't, so I can't complain. For whatever it is worth, it sounds great (the stroker has a lot to do with that too, and the 2.5" exhaust), holds up great (so far), I would reccomend it.
Old February 17th, 2014, 08:12
Talyn's Avatar
Talyn Talyn is offline
The two piece shorty header isn't as prone to cracking as the earlier headers are. It would help, but if you have the Flowmaster cat back kit its only 2.25" tubing which isn't helping anything.
Old February 17th, 2014, 09:18
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
The modern Banks headers do not crack the way the original ones did.
We have two seasons of racing at 3 King of the Hammers on our Banks header, no cracks. It flows excellently, fits really well.
I would most definitely run it again. Even if they didn't use our car in their ads.
I do challenge you to find anyone who has more experience with this header than we do.
Old February 22nd, 2014, 16:18
2001XJ's Avatar
2001XJ 2001XJ is offline
I was tossing around Banks but ended up going with Clifford Performance....
http://www.jeep4.0performance.4mg.com/exhaust.html
2000
4wd
4.0
156k
thanks,
Mike
Old February 22nd, 2014, 18:38
cal's Avatar
cal cal is offline
That webpage has some serious bad info on it.
18 to 22 % gain from doing a header?
Old February 22nd, 2014, 19:19
NW-ZJ-SCOTT's Avatar
NW-ZJ-SCOTT NW-ZJ-SCOTT is offline
I was thinking that seemed odd
ZJ, Atlas 4 speed
MJ, 4.0HO Shortbed
Headers - Are they worth it? School Bus Man Modified Tech Discussion 30 June 7th, 2008 20:59
just my experience with banks headers ranger125 Modified Tech Discussion 17 February 3rd, 2008 23:35
ARB ss line upgrade worth the coin? MMIXJ Modified Tech Discussion 8 May 20th, 2004 08:04
Banks Headers KLXJ Modified Tech Discussion 5 November 4th, 2003 18:27
Banks Headers 5-90 Modified Tech Discussion 22 April 27th, 2003 11:49
