sjstar
- san jose, ca
Hi, I hate to sell my Cherokee its been a long time dream but times have changed. So much new stuff with very little miles on any of it and really all easy miles.
Spent a lot of time listing everything out so please read before contacting.
1998 Jeep Cherokee sport 4x2
117,*** miles
current reg., pink slip in hand, and smogged
Engine:
Stock engine with just modified stock air box,exhaust, and bored out throttle body
Transmission:
Automatic with only 6,000 since full rebuild
Radesign baja II shifter to manually control the transmission
B&M aux. transmission cooler
Completely new rear driveshaft
Axles:
Rear end is a chrysler 8.25 fully trussed and gusseted
Alloy USA axle shafts
very new 4.56 gears with a powertrax locker
Front end started as a stock 4x2 axle meaning the same as 4x4 less pumpkin
Fully trussed and gusseted
Currie upper control arm axle mounts with johnny joints
Chromoly tubing pressed through the center of the axle tube then welded together
Drilled and slotted roters
v8 grand cherokee hubs
Moog ball joints
Interior:
Aftermarket deck and speakers
Clean interior with no rips in the seats
Cold ac and hot heater
Pwr windows and locks
Gauge cluster has tack
Cobra cb radio and whip
Exterior:
Decent original black paint
Fiberglass baja front fenders
Tube bumpers front and rear
HID 7" off road lights
Suspension:
Deaver custom made leaf springs for a particular jeepspeed race cherokee
temporary rubicon express rear shocks in stock locations
Rubicon Express V8 grand cherokee 5.5 inch lift front coils
Fox 2.0 double bypass big shaft piggy back rez. shocks up front
Fox 2.0 2" travel hydro bump stops up front
13" Polyperformance limit straps up front
Rubicon express lower control arms
Rusty's adjustable upper control arms
Rubicon express HD track bar, mount, and brace
Other:
DOM tube frame strengthening kit from front control arm area under jeep back to front leaf spring mount
Complete frame plating around front suspension area tied in with front bumper
New steering box
New power steering pump
Steering box brace
Currie drag link and tie rod
American racing aluminum fake bead lock wheels
BFG Baja t/as 80% tread left. size is 33x10.5x15 straight off a sponsored jeepspeed race cherokee
Trailer hitch tied into body strengthening
optima battery
Steps left to do:
Cage the interior
make mounts off interior cage and off leaf spring mounts to attach 12" travel shocks of your choice
limit strap the rear for the shocks that would be put in
make lowered mounts for stock rear bump stops
This jeep is completely drivable and off-roadable right now the limiting factor is the rear shocks. Could be left the way it is like many poser prerunners you see around or just finish it up and have one hell of a capable jeepspeed prerunner. Everything that has been done to it or installed has very little miles on it maybe 2,000 max. Much is actually near brand new. Adult owned and cared for very well this is not a hacked together wanna be prerunner.
Possible sale of items left to complete the Jeep:
60 feet of 13/4" DOM tubing
Fox 2.5 double bypass 12" travel shocks for the rear
Call or text 4084214449 or pm
Serious buyers only, no low ball offers
Asking $6000
117,*** miles
Engine:
Transmission:
Axles:
Moog ball joints
Interior:
Exterior:
Suspension:
Other:
New steering box
Steering box brace
optima battery
Steps left to do:
Cage the interior
Asking $6000
