| Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Do NOT run v8 ZJ draglink in an XJ
I've been scrambling to track down a hard to find wobble at 60mph before my trip to Moab (from Maine) on Saturday. Everything was tight, but the steeringwheel would shake slightly and the my coffee would slosh around in the cup at interstate speeds. I spent hours under the jeep with a pry-bar and a jack trying to make anything move. I finally gave up and decided to hide the problem with a new steering stabilizer. The axle-side bolt was a little beat-up so I went back to napa with no stabilizer to get a new one. The jeep did not wobble!
I put the new steering stabilizer on with the new bolt and I had to force it to line up with the drag link side. The stabilizer wanted to be about 2" above the drag link. With the new stabilizer in place, my wobble was back. A little research showed that the ZJ drag link had a different stabilizer angle, but about half of the writeups out there recommend using the ZJ part. There is no reason to do that. It is no stronger than the XJ one and it may cause problems. Now to find a use for this extra ZJ drag link...
#2
Re: Do NOT run v8 ZJ draglink in an XJ
I ran the ZJ steering setup for years with no wobble, and no stabilizer. the advantage to the ZJ setup is the tie rod not the drag link. If i recal correctly you only need the tie rod not the whole setup. the ZJ tie rod is solid instead of the crappy hollow XJ one.
#3
Agreed, in case I wasn't clear, my post was about the drag-link only. The tie-rod is a definite improvement.
#5
Its been said already I guess...but yea tie rod only here as well and all fine with no vibes. The old XJ one got bent so it was a decent upgrade at the time.
#6
IIRC it's the same Part number for ZJ/XJ right side Tie rod end (aka.. drag link)
FWIW
ZJ, Atlas 4 speed |
#7
No, they are different:
XJ part: MOOG-DS1238 ZJ part: MOOG-DS1310 (DOES NOT WORK WELL ON XJ) Last edited by jeepingben; September 10th, 2012 at 17:40. Reason: mis-typed part number |
#8
I've had the whole setup on my DJ for 2 years with no issues....
#9
Stock steering is crap anyway. Currie is the best for a Jeep with 4.5" or less lift. Run the tie rod OTK and you've got high clearance, high strength steering with stock handling.
#10
mmmmmmmm, pretzles:
![]() FWIW, i bent my stock drag link and broke my stock tie rod in 2 after i bent my ZJ tie rod, the following day. its deffinantly an upgrade, but not bullet proof. i feel the bends in the ZJ drag link weaken it, though its still stronger than stock. |
#11
1ton is probabley the strongest!
#12
[cal]You're an idiot rockclimber. [StinkyFab]RockClimber is a tool. |
#13
Ummmmmmm, no issues with mine.
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon [QUOTE=*89Laredo*;246072645] The human skull makes quite a loud noise when it hits a metal chair. [/QUOTE] |
#14
I put the XJ drag link on tonight. It got rid of the wobble and it was obvious that it would before I even started the Jeep. When I had the ZJ draglink installed, kicking the inside of the tire caused the area where the tierod connected to the draglink to move quite a bit. With the XJ part installed, it looks much better. I should have made a video.
For those who prefer 1-ton steering, it probably makes sense for you, but ZJ steering makes sense for me. I bent 1 stock XJ tierod on my 91 XJ and I beat on that Jeep quite a bit. My current XJ is more of an adventure/expedition rig. If I do happen to bend the ZJ tie rod far from home, any parts store will have a replacement. I didn't expect such a lively thread. About half of the ZJ steering writeups include the ZJ draglink and I wanted to clarify that the XJ draglink should be used. I also wanted to make sure this thread would come up in a search for ZJ steering. |
#15
What year is your XJ?
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Draglink tie rod | 19864cyl | Modified Tech Discussion | 14 | October 27th, 2010 12:52 |
| New RHD draglink,used RR draglink | RCP Phx | Arizona For Sale/Wanted | 8 | October 9th, 2009 17:04 |
| rhd draglink | jmjbrokenj | Modified Tech Discussion | 5 | June 6th, 2007 02:28 |
| draglink | jeepjay90 | For Sale: Private Party Only. XJ ITEMS ONLY | 1 | February 11th, 2007 13:20 |
