jimchere
- Changes faster than I can update
'98 Cherokee classic (2wd, sorry) 4.0L bone stock with 8.25 Chrysler Posi-track rear. I changed the diff fluid (including additive) yesterday and was going for replacing the rear shocks (sprayed the shock mounting bolts with penetrating oil and let it work while doing the diff fluid). I was removing the left rear (driver's side) shock and got the two top bolts out. Went to remove the nut on the bottom shock mount and it sheared off on me:skull1:. Looks like the bottom shock mount is integral to the rear axle.
My first idea is to cut the bolt off flush with the axle bracket with a dremel, then drill through (pilot hole then increasing bit sizes) and replace with a high strength bolt (12-14mm). I'm overseas, only have access to metric and no welding gear. Just a dremel and decent drill. Any advice or other ideas from the forum would be most appreciated.
