Old May 17th, 2012, 11:28
dukie564's Avatar
dukie564 dukie564 is offline
Bacon...that is all
starter rebuild
anyone ever rebuild there starter and know where to find the kits to do so? I have found new brushes but that's it.
My starter is cranking really slow only when the engine is hot, so i'm fairly certain the motor is on it's way out.
1995 XJ Cherokee Sport
4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
4.5" Frankenstein Lift, 35x12.5 Cooper STT Pros
357,000 mi and runnin' strong
Old May 17th, 2012, 11:33
PaulJ PaulJ is offline
Re: starter rebuild
YES http://www.aspwholesale.com/
Old May 17th, 2012, 13:19
dukie564's Avatar
Bacon...that is all
Re: starter rebuild
pretty simple? Those come with instructions do you know?
Ignition? Starter Relay? Starter? RebelXJ OEM Tech Discussion 11 January 18th, 2012 11:03
need a new starter neversummer369 Colorado Chapter 4 March 17th, 2009 08:34
starter bad? pimpgixxer04 OEM Tech Discussion 5 October 7th, 2008 13:37
starter went out, fixed it, now starter doesnt get a signal?? HELP!! DangerousJordan OEM Tech Discussion 4 February 19th, 2007 17:43
I Need a Starter... Rock.Wgn OEM Tech Discussion 7 June 14th, 2005 13:29
