Old January 14th, 2012, 15:15
jeepsrock's Avatar
jeepsrock jeepsrock is offline
Arrow CA SMOG, HIGH NOx
The Jeep has failed CA Smog due to high Nox.
You can see the progress below and what i have done, i have no clue how else to go forward. Suggestions would be highly appreciated...
First Run.
* Checked Coolant Level and Aired Tires.
Uploaded with ImageShack.us
Second Run.
* New O2 Sensor (NGK 23023), Air Filter & Fuel Filter.
* SeaFoamed Engine.
* Checked for Vac Leaks.
Third Run.
* New Magnaflow Cat (39005).
- Strangely NOx levels went higher ?
Pete
Old January 15th, 2012, 10:30
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: CA SMOG, HIGH NOx
It is running too lean (and or too hot) for some reason. We need to know what year jeep it is next!
Other repair history? Plugs, wires, cap, rotor, Sensor tests, like CTS and IAT temperature accuracy....
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 15th, 2012, 10:43
Tuffnuttz Tuffnuttz is offline
Check EGR and catalytic converter.
Old January 15th, 2012, 10:55
Ecomike's Avatar
NAXJA# 2091
Read his post, the third step was a new Cat (magnaflow), and the NOx went even higher. EGR was only on Renix, 87-90, not on HO years 91-01, and we do not have the year spec yet from the OP.
Edit: I just checked the O2 sensor he used. It does not fit Renix, but fits HO years, so if he bought the right O2 sensor, his engine is an HO, 91-01, and does not have an EGR.
So that leaves a problem with O2 sensor wires, like the O2 sensor heater power relay and 12 volts to the O2 sensor internal electric resistance heater, or the computer, or a bad CTS, IAT, temp sensor(s), or a vacuum leak near the MAP sensor vacuum hose biasing the MAP sensor data, or a bad cooling system, letting the engine run too hot!!!!! Oh, and Exhaust manifold leak (gasket, crack or donut leak) could be confusing the O2 sensor!!!!!
I should not be ignition related, or even mechanical engine related (based on the low HC and low CO numbers), unless the cooling jacket is scaled up.
Old January 15th, 2012, 11:26
jeepsrock's Avatar
Arrow Re: CA SMOG, HIGH NOx
1994 Jeep Cherokee
4.0 6cyl
50 Series Flowmaster
Aftermarket Manifold installed ~6months ago.
Aug2011 (TuneUp)
* Coolant Flush
* Champion Plus and Rotor/Cap
* Oil Change & Filter
* Tightened Manifold/ Collector Bolts
All other sensors are at least 6-7 Years old.
Thanks so much folks,
Pete
Old January 15th, 2012, 11:46
5-90's Avatar
5-90 5-90 is offline
Correct heat range for plugs? Try going one colder, and see if that helps bring temperatures down.
Can you get to look through the spark plug holes somehow? You may carbon deposits, which will insulate the metal and prevent drawing off chamber heat and elevate combustion temperatures. I've posted elsewhere on how to deal with that easily and cheaply. Since it's a 1994, it may be due to be decarbonised anyhow - but it would help to get a look in and see what's going on down there.
New cat, no EGR OEM, so that shouldn't be at issue. It's not the after-treatment of the exhaust gas, it's not a failure of exhaust gas recirculation, although (given your HC and CO results,) I'm inclined to say you're running slightly lean. Try an injector cleaning as well.
Old January 15th, 2012, 11:58
Ecomike's Avatar
NAXJA# 2091
Aftermarket manifold may be part of the problem. No way I know of to confirm that. Have you checked for OBD-I codes with the key on-off, on-off, on....flash count light number count method for error codes?
I would get out the FSM and check the CTS and IAT temp sensors, hot resistance for bad data versus FSM data tables of resistance versus temp. Check the O2 sensor live and the 12 volts to the O2 heater and the two O2 sensor ground wires for resistance above .5 to 1.0 ohms....
http://www.naxja.org/forum/showthrea...+t est&page=7
What temps is the cooling system running at?
If it is running rich at idle due to a bad O2 sensor wire or heater voltage relay is bad, or bad wire, it could be running rich at idle, adding carbon the combustion chamber, than running too lean at loaded higher rpms due to carbon fouling, but I check that the O2 wiring is all good first, as a bad connection or wire can corrupt the data the ECU sees from the O2 sensor biasing the ECU to run the engine too lean because it thinks the engine is too rich.
Old January 15th, 2012, 12:01
Ecomike's Avatar
NAXJA# 2091
See OP, he seafoamed the engine (and installed a new O2 sensor) between tests 1 and 2, and NOx increased. Then he replaced the Cat between steps 2 and 3, and NOx got worse.
I hope he seafoamed, before he replaced the O2 sensor?
Note: He did not say how he seafoamed the engine. Perhaps he just cleaned the intake and added carbon the the combustion chamber?
Old January 15th, 2012, 13:20
5-90's Avatar
Could be. I probably glossed over the Seafoam part, but "Seafoaming" the engine still leaves some open ground (you can dump it in the intake - should get carbon, won't do anything to the injectors. You can dump it in the fuel - should clean the injectors, but won't do much against chamber carbon.)
I'm still leaning toward the mix being slightly lean - the reason I ask people to post all measured results from a failed smog is because they're all instructive.
Granted, his O2 is measured at zero, which kinds throws off the "running lean" bit. And, the CO2 is about right. It's the elevated NOx without a significant reduction in HC and CO that throws me a bit...
Old January 15th, 2012, 13:40
Ecomike's Avatar
NAXJA# 2091
Local smog guy here swears that running the cleaners through the injectors (gas tank) and the intake (via vac hose), has always fixed jeeps that failed just the NOx by a little bit, where everything else was already good, so you may be right about injector cleaner on this one, but I think he should also test the basic sensors. He should also check the spark plug number (which I do not think he posted, just the brand and type) he is using to see if they are too hot?
I had not looked at the O2, it is not always listed, or accurate in other states. Could near zero O2 affect NOx? Most curious trend in his O2 numbers!!!!
.2-.3 test one, then higher on test 2, .3-.4, then zero on test 3 with the new cat??????
I wonder if the tester is bad? But the HC dropped 10 fold on test 3!!!!
Any data available on aftermarket headers raising emissions?
I wonder if "seafoaming the engine", means the oil, intake manifold or gas tank now, LOL?
"Answer only import if ask right question" LOL. Next Karate Kid,
Old January 15th, 2012, 17:55
5-90's Avatar
Theoretically, you want to have zero O2 remaining - it shows that the fuel being delivered is sufficient.
You also want to have nearly no HC or CO - because either of those represents unburned or partially-burned fuel, respectively.
NOx isn't a product of combustion, it's a product of combustion temperature, which makes it a "flyer" on emissions testing results (HC and CO are from fuel not burning correct, CO2 is from fuel being burned properly, O2 is what is needed to burn the fuel. CO2 is going to be fairly low because it's almost naturally low enough to be considered a "trace gas," and the atmosphere only runs about 20-22% O2 anyhow (it's 70-odd percent nitrogen tho...)
Y'know, so much of the emissions headache could be avoided (and tailpipe emissions reduced to nearly nothing) if they would just allow us to use water/MeOH fogging in place of the wretched EGR system (and you could tune an engine to run much better on the fog than on EGR!)
Old January 15th, 2012, 18:09
ferntr33 ferntr33 is offline
You all sound like you know a lot more than I, but did you make sure the cat you got is the right cat for CA pre 1996? You might have gotten some douche who put the non CA cat on or something . . . maybe worth looking into.
Old January 15th, 2012, 18:18
kdailey4315's Avatar
kdailey4315 kdailey4315 is offline
How is your coolant temp sensor your cooling system in general? Is your jeep running hot? Higher temps can lead to higher NO.
Old January 15th, 2012, 23:46
jeepsrock's Avatar
Earlier today i checked the fuel pressure just for kicks, its about 34psi at primed cold state/engine off and varies from 32-38psi revving the engine.
The Seafoming engine treatment I mentioned was 1/2 a can down the Brake Booster Vac tube and the other 1/2 down the Fuel Tank which was indeed before the O2 replacement. I let it soak about 15mins and ran it on the highway a bit till the smoke stopped.
As for the Spark Plugs, i always use the recommended Champions since they have typically worked and felt the best. I haven't checked them lately since it seems a little premature ?
The Jeep Runs right in the middle as far as temperature, if it happens to climb up, the e-fan brings it right back down, which is normal as far as i know.
The manifold i am running is one like this,
http://static.1aautoimages.com/parti...0146/large.JPG
I will try to test the sensor data using a multimeter as mentioned above, in the mean time keep the ideas coming, i really appreciate it...
Pete
Old January 16th, 2012, 06:14
Ecomike's Avatar
NAXJA# 2091
I am not positive, but IIRC HO engines need 49-50 PSI fuel pump pressure!!!!!
You may have a bad check valve or loose hose in the fuel tank or a weak ground, thus slow pump speed?????? Loose hose or leaking fuel pressure regulator in the tank are common.
Also check that the fuel filter is good, install the right direction, and check for crushed fuel line tubing from the engine to the tank!!!
failed smog high NOx jeddins OEM Tech Discussion 20 March 31st, 2010 03:08
Failed CA Smog - High C0 HTeK OEM Tech Discussion 12 May 18th, 2007 12:47
CA smog failed, high CO GroversXJ OEM Tech Discussion 13 November 22nd, 2006 15:47
Smog test, high HC Paul S OEM Tech Discussion 20 November 8th, 2006 12:16
CA Smog-High NO Bronco OEM Tech Discussion 3 February 11th, 2006 13:43
