Old August 26th, 2011, 10:38
supertubesocks's Avatar
supertubesocks supertubesocks is offline
91 4.0 wont start please help!
Here's the quick version.
I have a 91 xj with 4.0 automatic 231j tcase.
The jeep was sitting for years and i just got it running. Then was forced to rebuild the engine. We got the engine back in and it wont start. The engine is getting fuel and spark. the exhaust is getting warm but just wont fire.
Here is the list of new parts.
plugs
plug wires
cap n rotor
Header
fuel pump and filter
crank position sensor
harmonic balancer
cam shaft
Please help with anything else to try.
Thanks in advance.
Old August 26th, 2011, 11:25
87manche's Avatar
87manche 87manche is offline
Re: 91 4.0 wont start please help!
timing
assuming you had the distributor out, double check it.
Old August 26th, 2011, 11:34
kdub41 kdub41 is offline
probably not it but check the neutral safety switch.I have a 96 cherokee and mine wouldnt start except for in neutral then it wouldnt start at all took out the safety switch and it was all gummed up. I had my buddy help me with it but i know how to do it now.
Old August 26th, 2011, 12:28
RyanKnol's Avatar
RyanKnol RyanKnol is offline
are the injectors firing? I had that issue once where after cleaning the injectors and putting them back in, i messed up the order of the wires, and it wouldnt start.
But I dont think youd be getting spark or anything if this were the case.
Old August 26th, 2011, 12:56
ehall's Avatar
ehall ehall is offline
it wouldn't turn over with a bad NSS
my '91 beater rebuild
Old August 26th, 2011, 12:59
ehall's Avatar
Hold the throttle down while you crank and see if it catches, this will bypass the IAC.
How are you testing fuel to the cylinders?
Old August 26th, 2011, 14:00
I've checked the fuel using the relief valve on the rail, and also used a stethascope on the injectors, they are all clicking.
We suspect timing is the issue, but it seems like the rotor is pointing at plug#1. Is there any other components in the ignition system to check?
The engine cranks and tries to fire but just wont run.
Old August 26th, 2011, 14:14
whooops i didnt see that is was turning over.
Old August 26th, 2011, 17:00
nblanton nblanton is offline
Do you have spark?
Old August 26th, 2011, 17:14
Originally Posted by nblanton View Post
Do you have spark?
Yes, we pulled the wires and put an old plug on them.
Originally we were only getting one spark but then i replaced the cps and it's getting good spark.
Could it have anything to do with the wiring harness hooked up incorrectly?
There were 3 wires with ring terminals on the left side of the engine bay that i just grounded to the engine block.
Is there an ignition control module that i can check?
Old August 27th, 2011, 06:38
djgrayxj djgrayxj is offline
Note from DJ
You might take a look at this posting
Renix distributor install walkthrough
http://www.naxja.org/forum/showthread.php?t=964617
Old August 27th, 2011, 10:00
Originally Posted by djgrayxj View Post
Note from DJ
Does that apply to HO distributors?
86 2.8L wont start it turnsover but it wont start black86xj OEM Tech Discussion 12 April 2nd, 2010 15:38
Wont start; Rough Idle and then stalls when it does start MudslinginXJ OEM Tech Discussion 17 February 24th, 2008 07:30
wont crank wont start nothing 90xjpos OEM Tech Discussion 13 February 6th, 2007 10:52
turns over once, wont start sounds dead but wont jump maxaud OEM Tech Discussion 5 November 16th, 2006 15:07
