Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old April 10th, 2011, 20:10
shortxjdoug's Avatar
shortxjdoug shortxjdoug is offline
Project "girly" jeep
So i wasnt gonna put this in adfab but since most of it is one off garage fab so i figured it was better suited for adfab than modtech.
So this all started when i put my girlfriend behind the wheel of the waggy and she rocked a wheelstand that would make any man proud So when she needed a new dd, she went out and bought a nice 2000 cherocar with a 4.0 and an aw4 trans. she then proceeded to head out and buy a d30 and 29 spline 8.25 with 4.56 gears, suffuced to say one trail of seat time has her hooked.
So the plan is as follows, three link front based off a crossmember running RE 5.5 coils and the old leaf springs and shackles out of my now scrapped wagoneer. Gonna get armored, rocker replacements, and planning on building a tire carrier and winch bumper and eventually a hybrid interior/exterior cage. Im keeping the drivetrain pretty simple, gonna run lunchbox lockers front and rear, and the sye off my old jeep.
the ride...
the shoes, 35x12.50x15 nokian vativa MT's
hdoffroad engineering frame stiffeners
drawing up and drilling the new crossmember. the new piece is 2x6x3/16 with 1/4" mounting plates
new crossmember before cleanup
i think i have to give more credit to the hobart than my skills for the decent lookin welds
finished trimmed and cleaned crossmember, going to backweld grade 8 nuts to the frame stiffeners to up the mounting points to 4 grade 8 bolts plus the 2 stock crossmember bolts for a total of six per side... should stay just fine.
Frame stiffeners are going in tomorrow along with the new crossmember, then ordering a set of steelies and link parts to finish up the suspension
Old April 11th, 2011, 04:30
chattacuda chattacuda is offline
Re: Project "girly" jeep
Looks like a great start. Don't you just love cutting and drilling that quarter inch steel? That stuff will be there a while for sure
Old April 11th, 2011, 05:56
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
I'll be following this Doug and hopefully seeing it at the crawl!
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
Old April 11th, 2011, 06:09
If you don't see it at the crawl ill be in the doghouse since she's dying.to get back to the dirt, I really want it ready to shake down in may if all goes right
Old April 11th, 2011, 15:00
Question Re: Project "girly" jeep
Welded up the passenger side stiffener today, backwelded 4 grade 8 nuts and cut pockets in the frame for them to sit in.... going to try to get the other one done tomorrow after class
Had an issue with the tip going south but I hadn't changed it since I bought the welder... so I have some cleanup to do before paint
Old April 11th, 2011, 15:14
FlexdXJ's Avatar
Where did you find her and does she have any sisters?
[/QUOTE]
Old April 11th, 2011, 15:18
One sister and she's already married...... I'm hanging on to this one with all I got, there aren't a lot of good lookin ladies out there willing to drop their tax return on jeep parts and love it.... you shoulda seen how happy she was when we brought those tires home
Old April 11th, 2011, 15:19
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
I woulda been happy too! I want them!
Old April 11th, 2011, 15:30
CherBear CherBear is offline
I thought you had gotten a Wrangler from the title of this thread
Old April 11th, 2011, 15:32
Jump This's Avatar
Jump This Jump This is offline
Just another minion!
I have heard many people say that using plate for your crossmember isn't going to cut it. Too much flex. Look into adding something across the top.
I used L shaped (not angle though) 1/4".
Old April 11th, 2011, 15:33
MoparManiac's Avatar
MoparManiac MoparManiac is offline
He's using 2x6x0.188" box.
That should be fine.
Old April 11th, 2011, 15:40
Lowrange2's Avatar
That's what I was thinking... I didn't see any plate either.
Old April 11th, 2011, 15:42
The only plate used is the 1/4 inch on the sides to mount it the xmember itself is 2x6 box
Old April 11th, 2011, 15:43
Lowrange2's Avatar
I don't see why that won't hold just fine.
Old April 11th, 2011, 16:01
Jump This's Avatar
I missed the box part. That should good...
Rate This Thread:
Trucks Builds project "Cheap Cherokee" (full episodes) boostamante SoCal Chapter 22 August 5th, 2013 03:25
"Project" Jeep XJ Wiser SoCal Chapter 11 March 11th, 2010 09:34
FS: 15"x8" Jeep Ravine Wheels & 30"x9.5"x15" Wrangler GS-A's arfinsd SoCal For Sale 0 February 16th, 2008 21:54
Found a Jeep for my "street Jeep" project.. ZachMan Jeep Street and Performance 6 April 12th, 2007 09:29
Project "Salvage Monkey" underway axle questions BUCKYXJ Modified Tech Discussion 1 July 28th, 2003 07:26
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
