Old February 18th, 2011, 08:32
Blind Driver Blind Driver is offline
Sneak Peak:Rough Country Winch Bumper
ok so I'm a fan of Rough Country on Facebook and instead of doing an essay I stumbled upon this photo they leaked
the caption said Sneak Peek: Prototype Steel Bumper with Stinger and recessed Winch Mount area.
whats everyones opinion?
Old February 18th, 2011, 08:43
anthrax323 anthrax323 is offline
Re: Sneak Peak:Rough Country Winch Bumper
Looks like they're trying to compete with the approach angles of Ranch Hand's products.
Seriously, though... It looks nice, but looks like it sticks out 11" or more.
Old February 18th, 2011, 08:52
robsjeepxj robsjeepxj is offline
Looks good I'm sure people will buy it but yeah that does look like it sticks out a lot. Maybe it's the picture but it looks like the stinger doesn't mate up to the top of the bumper that well, the angles look off.
Old February 18th, 2011, 08:55
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Park bench
Old February 18th, 2011, 08:56
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Meh, its ok. It does stick out a lot and I have never been a fan of stingers bolted on.
Old February 18th, 2011, 09:04
GRIMUS99XJ's Avatar
GRIMUS99XJ GRIMUS99XJ is offline
NAXJA Supporting Vendor
its 9" from grill to tip
The stinger can be easily welded on we made it bolt on for shipping reasons. This way it douesnt have to be shipped LTL but can go ups
Old February 18th, 2011, 09:07
srmitchell srmitchell is offline
I think it should be 2 inches shorter, and make it so you have to trim the grill around the winch.
Old February 18th, 2011, 09:16
GRIMUS99XJ's Avatar
What would be the advantage of that? Pros and Cons? If we shortened it and people had to cut the grill not as many people would be ok with that, remember we build our products tough enough for wheeling but still nice enough for mall crawlin. We have to meet the needs and wants of the masses.
However this is one reason why we post on the forums to get feedback and take what advice we can.
Thank you for your support and suggestions
Old February 18th, 2011, 09:18
Have you guys ever thought about reinforcing the stock crossmember and having the winch mounted behind it?
Then basically build the bumper off of that to be high clearance.
A lot of the time the mall crawlers just buy whatever the wheelers buy, hence the term "poser".
Old February 18th, 2011, 09:21
XJLI XJLI is offline
Originally Posted by MoparManiac View Post
Park bench
eyeing little girls with bad intents?
Old February 18th, 2011, 09:23
Pro-
Clearance?
Con-
You might lose a mall crawler "best of show"?
Old February 18th, 2011, 09:25
foxwar71 foxwar71 is offline
snot running down his nose?
Old February 18th, 2011, 09:26
Originally Posted by srmitchell View Post
Pro-
Clearance?
Con-
x2
the stock xmember is a joke... if you pull the bumper off, and kick it, itll bend in. a bumper with a replacement one (where you have to cut the stock xmember out) would be awesome for people who dont want to/cant weld in a replacement themselves.
Old February 18th, 2011, 09:31
x2
Most of us are scared of cutting.
Old February 18th, 2011, 09:33
I don't think you need to necessarily get rid of the stock crossmember (you'd need to build tabs to hold the bottom of the radiator), but I think part of it would involve cutting the center face out.
Not to mention you'd need to brace the frame rails somehow before you cut it out. They move quite a bit if you cut out the crossmember.
I still think it's the best approach I've seen. I had an AJ's slikrok bumper and while it was pretty good at maintaining a decent approach angle, throwing the winch behind the crossmember gets you the best angle.
rough country 4.5 kit filterbiz Modified Tech Discussion 1 September 14th, 2010 06:17
Sneak Peak - Warrior Products XJ Rear Bumper WheelinJR Jeep Picture Showcase 7 June 21st, 2008 16:29
Sneak Peak, XJ Low Profile Roof Rack jcroffroad NAXJA Vendors Info and Feedback Forum 36 June 19th, 2008 20:22
Rough Country kit, what's your opinion of the Rough Country kit? Fantobacon Modified Tech Discussion 34 December 14th, 2006 21:09
sneak peak Led Modified Tech Discussion 43 July 16th, 2004 15:01
