Old September 16th, 2010, 15:57
nwcherokee nwcherokee is offline
Yes another question about bleeding the brakes
I am installing extedended SS brake lines, front & rear. I've only bled brakes on a 60's VW Bug before. Is there anything different that I should know before trying this? My XJ is equipped with ABS, is that going to change things? I've heard it's best to go in order of RR, LR, RF, LF. The way we did it back in the day was pump up the brake, crack the screw, close, pump some more and so on. Any better methods i'm unaware of?
Thanks
-Nick-
Old September 16th, 2010, 18:43
jeep ride's Avatar
jeep ride jeep ride is offline
Re: Yes another question about bleeding the brakes
That's the way I do mine with no problems.
Old September 16th, 2010, 19:03
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
Vac. bleed is best, but that should work for ya too.
Old September 17th, 2010, 04:03
UKJEEP UKJEEP is offline
In my limited (no pun intended) experience, bleeding XJ brakes is well nigh impossible because - like just about everything else - the bleed nipples will be seized solid!
Old September 17th, 2010, 07:22
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Pumping the pedal and opening the screw, etc., is OK, especially if you have a patient partner, but if you're replacing whole lines it will take a long time. Vacuum bleeding is a bit quicker, as well as convenient for doing alone.
For small occasional bleeds, I have an old tailgate strut to which I put a little U-shaped block at one end to hook under the steering wheel. Pump up brakes, hold pedal down with strut, then go down and open the bleeder. It's slow and tedious, but effective if you're working alone without a vacuum pump.
Old September 17th, 2010, 07:28
ehall's Avatar
ehall ehall is offline
vacuum bleeding sucks (), pressure bleeding is best way to do it. Motive sells one like this but you can make your own with a spare master cylinder cap and a garden pump
Fill it with brake fluid and force the old crap out
my '91 beater rebuild
Old September 17th, 2010, 08:12
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
X2, you are missing the first steps - torque off old bleeder screws, curse a lot, walk to parts store, buy new drum brake cylinders, replace drum brake cylinders!
I have never had a problem with the front bleed screws, they seem to be more out of the weather and are a larger size so they can still be turned after corroding somewhat. The rears are often a disaster however.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old September 17th, 2010, 10:46
EMSJEEP's Avatar
Having converted my D35 drums I have no problems with the rear caliper bleeder screws...when the differential isn't exploded in one manner or another. I have always had problems getting a good bleed, stock or otherwise, a vac is probly the best way. I will be buying one next time, I'm sick of fighting with the whole system.
Please explain more about pressure bleeding??
Old September 17th, 2010, 13:38
sjx40250's Avatar
sjx40250 sjx40250 is offline
Gravity works if you have the time. Just keep fluid in res and a jar for each wheel. It will get all the air out. Vacuum will also suck air by the bleeder connectors leading you to think there is still air in the system.
Old September 17th, 2010, 15:33
joe_peters joe_peters is offline
One thing being overlooked is the ABS.
You need to bleed the brakes--gravity, pressure, foot pump.
Then you need to take it to a shop with a DRB scanner or equivalent so the ABS can be properly bled.
Good luck.
Old September 17th, 2010, 17:34
ehall's Avatar
Basically what the name says, it pressurizes the system and then you go around and crack the bleeders. This ways the old fluid is forced out, and there's no real opportunity for air to work back into the system, unlike gravity and vacuum bleeders.
http://www.youtube.com/watch?v=d0h5bMoW-aw
http://faculty.ccp.edu/faculty/dreed...eder/index.htm
I still use a home-made bleeder that works under pedal pressure (uses a check valve at the catch bottle) that is less sophisticated but not as effective. My setup can work with vacuum bleeding but my experience it never works right since I can't get a good enough seal to create suction and air always gets in.
Old September 17th, 2010, 17:53
98stocker 98stocker is offline
Start at wheel furthest from mc.
Fill mc.
Put some fluid in a jar, attach vacuum tube to bleeder, and drop end of tube into jar of fluid.
Crack bleeder open, have assistant in drivers seat press brake pedal slowly down.
Close bleeder, have assistant let brake pedal up. Repeat last two steps about 20 times.
Fill mc again, move on to next furthest wheel.
Repeat open, press, close, let up cycle about 10 times.
Fill mc again, move on to final wheels and repeat.
Don't press pedal up or down too fast, can cause air in lines to turn into tiny bubbles which don't like to leave the system for some reason. Dunno why.
Oh yeah. If you let the mc run dry accidently, bench bleed it and start over.
Old September 17th, 2010, 18:04
kastein's Avatar
likely hydrodynamic cavitation. I've noticed this as well. Let the pedal up too quickly and the localized pressure in the brake fluid temporarily drops below the vapor pressure, so the fluid boils in tiny spots.
http://en.wikipedia.org/wiki/Cavitat...mic_cavitation
Unrelated, but "7 degrees of wikipedia" found it, isn't science awesome? Sonoluminescence, i.e. making a fluid glow by subjecting it to intense sound waves. http://en.wikipedia.org/wiki/Sonoluminesence
Old September 18th, 2010, 13:45
lawsoncl lawsoncl is offline
Pretty cool stuff. Most of my cavitation experience is on the acoustics side. Cavitation emits lots of acoustic energy and can eat away metal pretty quick.
Old September 18th, 2010, 16:29
winterbeater's Avatar
winterbeater winterbeater is offline
Bleeding brakes: The best way is the GRAVITY method. The only problem is it takes a lot of beer and you don't want to drive right after. (CAUTION: YOU MUST BE 21 TO BLEED YOUR BRAKES THIS WAY!) I use it whenever I replace brake cylinders or calipers, but mostly it's just to change the brake fluid, which I do whenever I change shoes or pads. Ideally you change brake fluid at least every other year. If you worked on old cars and saw rusty pistons, you'd know why, but people also say that old brake fluid boils and won't stop you right.
1.) Get the car in a position where you can open up the bleeders. I always like to break them loose with a 6 point socket being careful not to break them off. If you can, spray them with breakaway or similar a day before.)
2) Starting with the bleeder furthest away from the master (pass. rear), open it about 1 turn. You can put a little hose and cup on it if you want to keep the old fluid from running all over. Make SURE to keep the master cylinder topped off with fluid and DON'T let it get down to where air gets back into the master cyl. Let it flow this way until the fluid comes out of the bleeder clean. This will take at least 2 cups or so of brake fluid. Using gravity alone, you can drink 2 beers while topping off the master cylinder for the first corner. (CAUTION: Do not store brake fluid in beer cans or put beer into master cylinder. Drinking a little brake fluid however will probably not kill you. Beer in your brake lines might.) Snug up bleeder good when you're done.
3.) Proceed to drivers rear and repeat. It won't take as long because the long brake line has already been purged of the old fluid. So you have to drink your beer faster.
4.) Pass front. Drink even faster.
5.) Drivers front. Etc.
Patience can be substituted for beers, but that's no fun.
This prevents the rubber pieces from going any further than they are used to and self destructing.
This should work fine with ABS systems too.
Question about line wrenches, flare nuts, and bleeding brakes JoshRountree OEM Tech Discussion 23 August 3rd, 2007 06:02
bleeding the brakes.... blackdoutxj OEM Tech Discussion 9 October 11th, 2006 09:32
Help!!! Bleeding brakes Powerman Modified Tech Discussion 22 April 9th, 2006 14:32
Bleeding brakes Cottontail OEM Tech Discussion 6 May 24th, 2005 06:47
Bleeding brakes - HELP!!!!!!! Uglygreenxj OEM Tech Discussion 5 May 12th, 2003 08:43
