Old September 2nd, 2010, 06:09
HarborJeep's Avatar
HarborJeep HarborJeep is offline
Motor Mount Bolt Size?
In crawling around under my new-to-me '98 XJ, I discovered a few missing nuts. The most serious one is the nut that attaches the motor mount to the "frame". It is show in this link http://www.jeep4x4center.com/product...umber=52040267 It is the bolt that comes down in the picture.
Does anyone know the size of this bolt so I can pick one up on my way home tonight? Thanks!
Old September 2nd, 2010, 07:21
HarborJeep's Avatar
Re: Motor Mount Bolt Size?
Just got off the phone with my new friend - the Jeep parts guy at the dealership. The bolt size is 12x1.75. I don't know what that means, but it is a size of nut listed on the Fastenal website. Hopefully this helps someone else!
Old September 2nd, 2010, 07:26
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
ahhh, they're metric then. M12 (12mm diameter) and 1.75mm thread to thread pitch. You want nuts with captive fender washers for the bottom of the mounts, a flanged staked nut for the top of the passenger side mount, and an M12x1.75 flange bolt of ISO property class 10.9 or above for the top of the driver side mount.
They take a 15mm wrench... that much I know.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old September 2nd, 2010, 07:36
HarborJeep's Avatar
Thanks kastein! That helps a bunch. The passenger side is missing and I notice the driver's side is definitely a replacement. Any ideas what the previous owner did or didn't do? The mount bracket looks new on the passenger side.
Old September 2nd, 2010, 07:38
kastein's Avatar
They probably just forgot to put them back on, or didn't tighten them down enough... you'd be surprised what some people will do to cars.
I've gone through this a couple times over the last two weeks due to pulling a drivetrain for a tranny swap, sadly didn't have new engine mounts on hand to install at the same time.
Old September 2nd, 2010, 09:24
joe_peters joe_peters is offline
While you are under there, take a look at the bolts that hold the mount brackets to the engine block--they like to fall out or shear off.
Old September 2nd, 2010, 09:29
HarborJeep's Avatar
"they like to fall out or shear off" - I wouldn't doubt if they have. It seems as if I've inherited all the "quirks" of an XJ. I'm finding most are fairly easy to fix and parts seem cheap. Is this the impression of others?
Old September 2nd, 2010, 09:54
kastein's Avatar
That's my general impression... it's why I own 3 XJ/MJ family vehicles now
Parts are even cheaper when you get em at the junkyard.
Old September 2nd, 2010, 10:50
"Salvage" yard for parts, junkyard for home decorations!
Need a bolt size for an AW4 tranny mount old_man OEM Tech Discussion 3 May 29th, 2009 23:43
shackle mount bolt size kidarkitect Modified Tech Discussion 11 January 28th, 2009 17:22
Bolt Head Size On 93' 4.0/AW4 Starter Motor Quarterwave OEM Tech Discussion 4 July 19th, 2006 08:49
Engine mount bolt size? stoneattic OEM Tech Discussion 3 February 9th, 2005 18:10
Engine Mount Bolt size?? Adam T OEM Tech Discussion 2 February 9th, 2005 14:42
