I modify the stock one the same way we used to before they were available.Pretty simple to do with a vice and hammer. I just did both of mine as I live at 5300 feet.
There is a thread somewhere in street&performance where someone showed how to build a nifty little bracket to get some ignition advance out of a 4.0 without a lot of trickery.
This might be hard to explain, but bear with me as I've modded about a dozen of these over the years on Renix Jeeps.
You want the black plastic piece, which sets in the center of the perforated mounting bracket, to be moved up toward the top of the bell housing.
Position the bracket in the vice loosely with the plastic part resting on the jaws. Insert one of the CPS bolts through the mounting hole above the jaws. Gently tap the bracket down through the plastic piece to the desired position, which happens to be about one plastic doohickey's width away from where you started.. The bolt keeps the hole in the bracket from getting crushed. Ask me how I know. Pay particular attention to where you want the doohickey to end up so you don't do it the wrong way.
I felt a slight difference in performance from this mod, but not as much as relocating the Intake Air Temp sensor from the intake manifold to the air filter box.
I'm a machinist and can certainly modify a cps to work as a high altitude unit. I just didn't want to have to mess with it. I simply wanted a brand new high altitude sensor.
By the way, I scored one locally at a good price. Thanks everybody.
The "other old man" was curious as to how you modified it--sounds simple enough, do you epoxy it in the new location or do they seem to remain tight enough after being moved?
Most peeps simply cut the side out of the hole on one end and oblong the hole on the other to offset the sensor. As it turns out, I got a MOPAR one for less than $35 through connections.
