Old July 9th, 2010, 17:40
lilredxj99 lilredxj99 is offline
? about cv style front axle shaft
I am bringing home a 94 xj w/ bad engine. Got a totalled 98 w/ a good motor.
Anyway, I found another XJ (early model Grand) w/ cv front axle shafts. Are these any axles better? or Worse?
I guess, I can probably get the whole axle on the cheap, plus a spare pass side shaft, just trying to figure out if itd be worth it or not.
Please don't give me the search lecture, I tried about 3x's and looked through at least 10 pages each time. It will not let you search "cv axle shaft". Just axle shaft ....
BTW, THANKS
Old July 9th, 2010, 18:16
NW-ZJ-SCOTT's Avatar
NW-ZJ-SCOTT NW-ZJ-SCOTT is offline
Re: ? about cv style front axle shaft
A: That "Early model grand" is not an XJ.. its a ZJ.
B:The cv axle shafts in that ZJ, Yeah.. they are garbage.
C:the CV drive shaft is NOT an upgrade. I have upgraded all of my ZJ CV shafts to XJ U-joint shafts
and i wont give you a search lecture, but i will give you a tip, When searching smaller phrases like "CV" etc etc. Use google. search "CV axle shaft " on google.
Hope that helps!
ZJ, Atlas 4 speed
MJ, 4.0HO Shortbed
Old July 9th, 2010, 18:50
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Add "site:naxja.org" to your google queries. Greatly simplifies searching for things on the forums here.
Old July 9th, 2010, 20:44
Talyn Talyn is offline
Not only that but the ZJs have the LP D30.
What year is your early Grand?
Old July 9th, 2010, 23:12
85 grand wagoneer, just wondering... it's got one of those diagnostics centers to the right of the cluster. kind of neat looking old xzj whatever. power everything.
didn't think about google though, thanks
Old July 9th, 2010, 23:29
in4aride in4aride is offline
Ya that wagoneer isn't a Zj.
Cv shafts like found in lp30's in zj's are garbage.
But aftermarket cv shafts like those from RCV are bad ass and likely the best shaft upgrade available.
Old July 10th, 2010, 01:12
xcm xcm is offline
post more info about the diagnostics center please.
Old July 10th, 2010, 05:39
Its an XJ, not a ZJ. But still the axles shafts are weak.
Old July 10th, 2010, 06:33
85xjwoody's Avatar
85xjwoody 85xjwoody is offline
For the street or EASY wheeling they cv shafts are fine, but for any harder wheeling I would go with u-joint axleshafts.
Old July 10th, 2010, 07:39
heyhar's Avatar
heyhar heyhar is offline
And, it's not a 'Grand Wagoneer'. Those were the old FSJs. About the time the XJ appeared, they called the wood version the Wagoneer, and Waggy Limited. The full size model got the 'Grand' moniker hung on it, to differentiate it. Either way, stay away from factory CV joints, ESPECIALLY twenty year old, used items. You'll be back in doing them real soon!
Old July 10th, 2010, 17:03
Its called the Sentry system. Not to be confused with the sentry key anti theft system.
Old July 11th, 2010, 01:19
austinaubinoe's Avatar
austinaubinoe austinaubinoe is offline
I saw a picture of that system before somewhere. Did it have an extra sensor in both axles, t case, engine, etc?
That would be a sweet mod to find one and ad the sensors so you could monitor fluid levels.
Front Axle Shaft/CV Joint HELP!!! DT|Ac1d OEM Tech Discussion 2 January 23rd, 2010 18:24
WTB D30 front axle shaft jeeperjohn SoCal Chapter 5 May 5th, 2006 22:18
front axle shaft question... Danno OEM Tech Discussion 2 February 15th, 2006 08:04
Front axle shaft stuck... thisfirstlove Modified Tech Discussion 15 August 11th, 2005 17:22
need help w/ front axle shaft gz32 OEM Tech Discussion 2 May 10th, 2004 07:38
