Old March 7th, 2010, 19:19
themangeraaad themangeraaad is offline
How do the power door locks work?
I don't have my Haynes handy so I can't look up wiring diagrams right now... do the lock actuators have two wires that run to them which would hint that the current flows one direction to lock and flows the other direction to unlock?
If that is correct, is one wire tied to ground while the other wire cycles from +12 to -12, or are both wires are at 0V normally and one of the two wires will increase to +12V when the switch is pressed (i.e. one wire goes to 12V to lock and the other wire goes to 12V to unlock)? Or is there some other way that the power door locks are operated?
Long story short I am looking to use an aftermarket remote door lock/unlock/alarm system to activate/deactivate different things in my XJ. I want to know how the locks work before I order the alarm system so I know whether or not I should expect my idea to work. I am hoping that pressing the lock button would put a 12V signal out on one wire, while pressing the unlock button would put a 12V signal out on a 2nd wire.... but I figure it might work in a different way which would mean I have some more work ahead of me to get this plan to work.
TIA
-Scott
Old March 7th, 2010, 20:24
ehall's Avatar
ehall ehall is offline
Re: How do the power door locks work?
There are two wires. Current flow is managed with dedicated lock and unlock relays.
my '91 beater rebuild
Old March 7th, 2010, 20:31
hmmm, guess I have to do some digging to find my haynes and find the wiring diagram then to trace the signals back through the relays. Thanks!
Power door locks don't work.... Torry H OEM Tech Discussion 4 October 19th, 2008 10:30
Power Door Locks?? NewToJeeps OEM Tech Discussion 6 March 3rd, 2008 17:20
Making power locks work, minus one door mjma OEM Tech Discussion 5 June 6th, 2007 17:53
Door weight: power windows/locks vs manual windows/locks 90Pioneer OEM Tech Discussion 1 July 4th, 2006 14:58
Help with power door locks... no power at pass. switch? NotMatt OEM Tech Discussion 7 July 27th, 2004 18:39
