Rear Sway bar parts and other things
RobDodge
Hancock Maryland
In rebuilding the suspension on my 94’ I found out that the rear sway bar brackets that hold it to the body were rusted out and have had no luck finding a vendor who sells them. I can find the front but not the rear
DayStar bushings have the mounting sleeve.
The local junkyard should have a few good ones.
I personally wouldn't even bother reinstalling rear sway bars. They aren't really necessary and from what I understand weren't even originally installed on some models. I don't run any and most people I know don't run rear sway bars on the xj.
My 1994 ad one. The 1996 do not. The 1996 do have stiffer springs so that may be the reason. I was not able to tell a difference when I removed the bar from the 1994.
Agreed
