As my '93 XJ is approaching it's 30th birthday in a couple of years, I have been thinking about the long term sustainability of the electronics onboard. What do I do if my electronics fail? My 4.0L has two fuel systems, the original MPI gasoline and an aftermarket propane system that was fitted twenty years ago. My goal is to get another 10 to 15 years from an engine rebuild assuming gasoline or propane is still available. A system that can also run on CNG is useful if propane availability reduces further were I live.
My propane system ECU is fairly simple to replace if it dies. It is no longer in production, but more fuel efficient systems are available now and they usually just need a timing source from ignition or cps and an oxygen sensor to run. Injector emulators are switched into the MPI circuit to prevent running on both fuels simultaneously.
However, my factory fitted ECU is more of a problem. Fortunately, my Jeep is pre-OBD2 so local emissions testing is based solely on what comes out of the exhaust. Perhaps I could replace it with a stand alone system like a MegaSquirt ?
My engine has a distributor ignition, but new stand alone systems like the MegaSquirt MS3-Pro can support coil-on-plug and wasted spark ignition. I am thinking that perhaps I could eliminate the distributor when rebuilding the engine and go to full electronic ignition using either the factory 2000+ coil packs or AEM Smart Coils with a stand alone system. The advantage of doing this is that my 2001 already has distributorless ignition so the same stand alone electronics system could be used on that too at a later date.
My AW4 is the older style with the separate transmission control module. Electronics replacement here could be NiftyShifter, or CompuShift.
ABS has already been junked. Is there anything else I have missed?
Has anyone already got to this point with a Renix system?
