GraniteCow
- USA
My check engine light is on (but very dim) and it’s throwing code P0463: fuel level sensor A circuit high input. I’m using a code scanner that lets me delete codes.
I replaced the sending unit in the tank, and it’s still throwing the code. I unplugged the pump/sending unit, and it’s still throwing the code. I unplugged the instrument cluster, and it’s still throwing the code. The fuel gauge reads half full by the way, so it looks to me like it’s getting a proper signal. Any idea what might be causing this? Could it be a bad ECU?
