yzmuddereffer
- Ohio
Installing OME CS033RBs onto my 2000 XJ. I have the leaf springs mounted, with a 2-degree shim. The leaf spring pin is an inch off. Pics below.
I've tried moving the axle forward, but it won't go. You can see one end of a ratcheting nylon strap that I thought might do the trick, but nope.
Do I need to drill a new hole through the springs or what?
Edit: Actually, what about drilling a new hole in the U-bolt plate? I can get the pin to drop into the front hole on the axle mounting surface.
Thanks in advance!
Thanks in advance!
